Help! The water just keeps filling up the tub? If set on small load, the water just keeps on coming in and in and eventually overflows all over the floor. I can drain the water by putting the washer on spin, but what part needs to be replaced? Is there a water level sensor of some sort? Thanks for any assistance one can give, Jules :eek:
Here are your parts Replacement parts for General Electric WHSE5240D1WW Washer | AppliancePartsPros.comIf you can stop the water flow by unplugging the unit or turning the timer to ff then the water level switch (Item 10 in Section 1) is the probable culprit. If the only way to stop the flow is to shut off the taps then the water valve (Item 805 in Section 1) is the likely culprit. Once activated it is sticking open. If it is the former. This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate. Possible problems. 1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug. 2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it. 3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard. If you cannot stop it the switch is toast. Note: That you may be able to stop it by blowing into then tubing and it may still be no good as it needs too much pressure to activate the switch. So if the tubing is OK replace the switch. |
THIS FORUM IS DEAD!!!!!!! |
