| » Washer will not spin but drains, etc. |
Model Number: 970-C40042-00 Brand: Kenmore Age: 5 - 10 years
I was wondered if someone can give me suggestion on my Kenmore washer that died last night. The unit was purchased in Canada thru Sears and model number is 970-C40042-00 which is very similar to Frigidaire LTF530FS0. This is a front loading machine. The unit worked fine with little louder spining than normal until last night. The unit stopped in the middle of washing cycle and the drum would not rotate. I manually advanced the timer by one step and the drain pump started working, then another step to final spin and nothing. Then I decided to move it back to the begining of cycle and the water dispencer hot / cold seems to be working ok. Then again no matter what position the timer was at there was no drum movement. Apparently when the timer was positioned in the middle of cycle the whole machime vibrates a bit. I had the feeling that some motor must be working. There was also some water at the bottom indicating a minor leak. When I managed to open the door I moved the drum from inside and it moved freely. So, I hope this is not too confusing. Any idea what's wrong with it? Is it cooked? Thanks xevier69 Related Models |
| Display Modes | |
| my washer won't spin | jopas213 | Washer Repair | 8 | 10-23-2008 01:03 PM |
| Washer will spin slowly but not drain | Mikie Martin | Washer Repair | 0 | 07-31-2007 08:36 AM |
