It Stoped Spinning Last Week End. I Took It Apart And Checked Out The Clutch And Brake. They Look Ok. I Found That When I Tilted The Mashine While Running It Started To Spin And As Soon As I Set It Uprite Again It Stoped Spinning. The Whole Time The Motor Is Running And All Sounds Normal. Philip
Check the motor drive coupling (#13 on the diagram). Gene.
