Discuss
Water remaining in washer after spin cycle
 in
Washer Repair
At the end of my spin cycle, there is water remaining in my washer. All the belts are okay. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water remaining in washer after spin cycle
  #1 (permalink)
Old 03-05-2009, 10:55 AM
Junior Member
heartmd is on a distinguished road
Default Water remaining in washer after spin cycle
Model Number: LA4910   Brand: Maytag   Age: 1 - 5 years
At the end of my spin cycle, there is water remaining in my washer. All the belts are okay. I am no expert, but could this be a problem with the pump?
The pump belt appears okay. The pump is adjusted all the way to the right. Anyway, I dont think these washer belts are meant to be very tight. What could be the problem?
Related Models
Maytag LA4910 WASHER-TOP LOADING
Maytag LA5000 WASHER-TOP LOADING
Whirlpool LA5000XMW0
Whirlpool LA5000XPW0
Whirlpool LA5000XPW1
Whirlpool LA5000XPW2
Whirlpool LA5000XPW3
Whirlpool LA5000XPW4
Whirlpool LA5000XPW5
Whirlpool LA5000XSW0
Whirlpool LA5000XSW1
Frigidaire LA500AXD5 Wwh(v2) / 27 " Washer
Frigidaire LA500AXD6 Wwh(v2) / 27 " Washer
Frigidaire LA500AXW5 Wwh(v1) / 27 " Washer
Frigidaire LA500AXW6 Wwh(v1) / 27 " Washer
Frigidaire LA500EXD3 Wwh(v6) / Top Loading Washer
Frigidaire LA500EXF3 Wwh(v7) / Top Loading Washer
Frigidaire LA500EXH3 Wwh(v8) / Top Loading Washer
Frigidaire LA500EXV3 Wwh(v9) / Top Loading Washer
Frigidaire LA500EXW3 Wwh(v10) / Top Loading Washer
Frigidaire LA500JXD3 Wwh(v11) / Washer
Frigidaire LA500JXD4 Wwh(v11) / Top Load Washer
Frigidaire LA500JXD5 Wwh(v7) / Top Load Washer
Frigidaire LA500JXF3 Wwh(v12) / Washer
Frigidaire LA500JXF4 Wwh(v12) / Top Load Washer
Frigidaire LA500JXH3 Wwh(v13) / Washer
Frigidaire LA500JXH4 Wwh(v13) / Top Load Washer
Frigidaire LA500JXH5 Wwh(v8) / Top Load Washer
Frigidaire LA500JXV3 Wwh(v14) / Washer
Frigidaire LA500JXV4 Wwh(v14) / Top Load Washer
Frigidaire LA500JXW3 Wwh(v15) / Washer
Frigidaire LA500JXW4 Wwh(v15) / Top Load Washer
Frigidaire LA500JXW5 Wwh(v9) / Top Load Washer
Frigidaire LA500MXD1 Wwh(v3) / 27 " Washer
Frigidaire LA500MXD2 Wwh(v3) / 27 " Washer
Frigidaire LA500MXH1 Wwh(v2) / 27 " Washer
Frigidaire LA500MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA500MXW2 Wwh(v1) / 27 " Washer
Maytag LA503 WASHER-TOP LOADING
Maytag LA506 WASHER-TOP LOADING
Maytag LA510 WASHER-TOP LOADING
Whirlpool LA5100XTF0
Whirlpool LA5100XTF1
Whirlpool LA5100XTG0
Whirlpool LA5100XTG1
Whirlpool LA5100XTM0
Whirlpool LA5100XTM1
Whirlpool LA5100XTN0
Whirlpool LA5100XTN1
Whirlpool LA5100XTW0
Whirlpool LA5100XTW1
Frigidaire LA510MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA510MXW1 Wwh(v1) / 27 " Washer
Maytag LA510S WASHER-TOP LOADING
Maytag LA511 WASHER-TOP LOADING
Maytag LA511S WASHER-TOP LOADING
Maytag LA512 WASHER-TOP LOADING
Maytag LA512S WASHER-TOP LOADING
Frigidaire LA515LXD1 Wwh(v2) / Top Load Washer
Frigidaire LA515LXW1 Wwh(v1) / Top Load Washer
Whirlpool LA5200XTF0
Whirlpool LA5200XTF1
Whirlpool LA5200XTG0
Whirlpool LA5200XTG1
Whirlpool LA5200XTM0
Whirlpool LA5200XTM1
Whirlpool LA5200XTN0
Whirlpool LA5200XTN1
Whirlpool LA5200XTW0 WASHER
Whirlpool LA5200XTW1 WASHER
Whirlpool LA5243XYN0
Whirlpool LA5243XYN1
Whirlpool LA5243XYW0
Whirlpool LA5243XYW1
Whirlpool LA5280XTF0
Whirlpool LA5280XTF1
Whirlpool LA5280XTG0
Whirlpool LA5280XTG1
Whirlpool LA5280XTM0
Whirlpool LA5280XTM1
Whirlpool LA5280XTN0
Whirlpool LA5280XTN1
Whirlpool LA5280XTW0
Whirlpool LA5280XTW1
Whirlpool LA5300XKW0
Whirlpool LA5300XKW1
Whirlpool LA5300XMW0
Whirlpool LA5300XMW1
Whirlpool LA5300XPW0
Whirlpool LA5300XPW1
Whirlpool LA5300XPW2
Whirlpool LA5300XPW3
Whirlpool LA5300XPW4
Whirlpool LA5300XPW5
Whirlpool LA5300XSF1 AUTOMATIC WASHERS
Whirlpool LA5300XSF2 AUTOMATIC WASHER
Whirlpool LA5300XSG1 AUTOMATIC WASHERS
Whirlpool LA5300XSG2 AUTOMATIC WASHER
Whirlpool LA5300XSM1 AUTOMATIC WASHERS
Whirlpool LA5300XSM2 AUTOMATIC WASHER
Whirlpool LA5300XSN0 AUTOMATIC WASHER
Whirlpool LA5300XSN1 AUTOMATIC WASHERS
Whirlpool LA5300XSN2 AUTOMATIC WASHER
Whirlpool LA5300XSW0
Whirlpool LA5300XSW1
Whirlpool LA5300XSW2
Whirlpool LA5300XTF0 AUTOMATIC WASHER
Whirlpool LA5300XTF1 AUTOMATIC WASHER
Whirlpool LA5300XTG0 AUTOMATIC WASHER
Whirlpool LA5300XTG1 AUTOMATIC WASHER
Whirlpool LA5300XTM0 AUTOMATIC WASHER
Whirlpool LA5300XTM1 AUTOMATIC WASHER
Whirlpool LA5300XTN0 AUTOMATIC WASHER
Whirlpool LA5300XTN1 AUTOMATIC WASHER
Whirlpool LA5300XTW0
Whirlpool LA5300XTW1
Whirlpool LA5310XPW0
Whirlpool LA5310XSW0
Whirlpool LA5311XPW3
Whirlpool LA5311XPW4
  #2 (permalink)
Old 03-05-2009, 12:52 PM
Junior Member
Default Washer is dead now!
Initially the waher would not pump out all the water after the spin cycle.
After reading that one has to first see if the pump is pumping out all the water in the tub within 90 secs, I let the tub fill fully and it hardly let out an inch of water. Water was splashing over the sides of the top of tub and onto the sides of the outer tub.
Then after 2 mins the whole unit went dead.
I hand drained the water from the tub using a cup. Now, operating the controls will not let any water in. No cycle will work.
I opened up the control panel and saw a fuse back there that had blown. Not knowing the amperage of the fuse, I removed to brown wire to the water level switch and the 2 white wires with green stripes (coming from the check switch and the water valve). These were the wires connecting to the blown fuse. When I taped them together, the circuit breaker for the house blew.
I suspect the high water level and splashing around, made the check switch/water level switch or water valve short out and blew the fuse. The condition has not been rectified so the fuse blew again.
After rectifying this and making the unit start, I know I have a drainage problem that started all this. The pump does move by hand. I will open and check the hoses for blockages.
  #3 (permalink)
Old 03-05-2009, 12:53 PM
Junior Member
What do I do now?
How do I make the fuse not blow once again?
Just wait until everything dries out?
  #4 (permalink)
Old 03-05-2009, 03:20 PM
Junior Member
Default The washer retaining water was due a sock in the tub outlet but HELP why did the fuse
I fixed the water stagnating in the tub. It was due to a sock between the inner and outer tubs.
But why did the tub lid fuse blow?
Why does it keep blowing?
Why does one have to replace the tub lid switch and the moniter switch?
Cam someone explain this to me?
  #5 (permalink)
Old 03-05-2009, 08:51 PM
Junior Member
Default I have reasons to believe that my lid switch is okay. It moves freely and the resist
I have reasons to believe that my lid switch is okay. It moves freely and the resistance between terminals when the white plunger is depressed is 0mohms and more than 200K ohms when the white plunger is let out.
The same occurs for the smaller switch between the white wire with green stripe and the red wire. 0 ohms when depressed and more than 200K ohms when let out.
While I was testing the tub for water drainage, i filled the tub to the top and measured how much time it took for the tub to empty in the spin cycle. It took more than 2 mins and hardly emptied (there was a sock stuck which has been removed). While this test was going on the motor sort of labored trying to spin a tub full of water. It did for 2 mins and then stopped which is when the fuse blew. I think my problem has some serious short some where.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
why would washer spray water on final spin cycle Ohiojeff Washer Repair 3 12-16-2017 04:24 PM
Extended Spin (8 min remaining) will not clear Gravy Washer Repair 11 07-28-2010 06:57 PM
washer fills with water and spin when cycle is started huan1 Washer Repair 1 04-01-2009 01:31 PM
Whirlpool washer spin cycle doesn't remove all the water suepar Washer Repair 1 09-29-2008 07:40 PM
Washer tub fills with water after the spin cycle completes vinnyvmj Washer Repair 0 02-17-2008 09:09 AM
