Discuss
Grinding
 in
Washer Repair
I have a maytag washer that is making a metel on metel grinding noise ( like a bearing going bad ). It
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Grinding
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-15-2007, 07:04 PM
bsmokey bsmokey is offline
Junior Member
bsmokey is on a distinguished road
Default Grinding
Model Number: LA412   Brand: Maytag   Age: More than 10 years
I have a maytag washer that is making a metel on metel grinding noise ( like a bearing going bad ). It sounds as if it is coming from between the two tubs. Whats the trick to seperating the two tubs?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 06:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would recommend to do is remove the front panel and check for water leak from the central seal.
Sounds like the problem is a bad central bearing and usually it happens when the central seal is leaking.
Inspect the washer and post your findings.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loud grinding noise instead of draining/spinning jpolett Washer Repair 10 01-23-2008 12:41 PM
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 07:20 PM
grinding noise while agitating sfuerte01 Washer Repair 1 10-20-2007 03:24 AM
Grinding Microwave HandyWoman Microwave Repair 0 09-29-2007 07:59 PM
Grinding, humming sound underneath while washing MGSHAFFER Dishwasher Repair 1 08-07-2007 12:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
