| » Grinding |
Model Number: LA412 Brand: Maytag Age: More than 10 years
I have a maytag washer that is making a metel on metel grinding noise ( like a bearing going bad ). It sounds as if it is coming from between the two tubs. Whats the trick to seperating the two tubs?
The first thing I would recommend to do is remove the front panel and check for water leak from the central seal.
Sounds like the problem is a bad central bearing and usually it happens when the central seal is leaking. Inspect the washer and post your findings. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| Loud grinding noise instead of draining/spinning | jpolett | Washer Repair | 10 | 01-23-2008 01:41 PM |
| Washer won't complete cycle-grinding noise | rebekah | Washer Repair | 2 | 12-13-2007 08:20 PM |
| grinding noise while agitating | sfuerte01 | Washer Repair | 1 | 10-20-2007 04:24 AM |
| Grinding Microwave | HandyWoman | Microwave Repair | 0 | 09-29-2007 08:59 PM |
| Grinding, humming sound underneath while washing | MGSHAFFER | Dishwasher Repair | 1 | 08-07-2007 01:29 PM |
