Discuss
Maytag top load washer wont drain
 in
Washer Repair
Looking for some help guys.My washer wont drain but the tub does spin and i can see the pump pulley
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag top load washer wont drain
  #1 (permalink)
Old 06-20-2011, 08:58 PM
Junior Member
punkinman is on a distinguished road
Default Maytag top load washer wont drain
Brand: Maytag   Age: 5 - 10 years
Looking for some help guys.My washer wont drain but the tub does spin and i can see the pump pulley turning.Also the tub doesnt seem to be spinning as fast as it should.I can stop it with my hand very easily and spin it backwards while it is running.I did put the drain hose in a 5 gal bucket and the tub drained.I am thinking belts but wanted some advice.Thanks for any help. UPDATE:This morning the tub spins very fast and does empty.I am at a loss.UPDATE 2. Tonight it is back to not spinning fast and also leaking water during the spin cycle.Help please!
Ads By Google
  #2 (permalink)
Old 06-23-2011, 06:04 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Sounds like an obstruction in the hoses or pump. Check them out, and if you need more help we need a model number.
Thanks and good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
G E Top Load Washer wont drain w/full load Mike 384 Washer Repair 1 02-05-2011 05:11 PM
ge profile top load washer wont drain E31 code bigmikethewizard Washer Repair 0 10-16-2010 08:48 AM
Maytag Legacy wont spin with a full load kansas Dryer Repair 0 01-20-2010 07:49 AM
Maytag washer wont drain on spin cycle Jacko1002 Washer Repair 2 08-02-2009 08:07 AM
Maytag washer wont drain RMOODY Washer Repair 1 07-12-2009 07:22 AM
