The Atlantis will not spin. I bought a thrust bearing kit from APP and received it today and installed it. Still no spin. The rest of the washing cycles are fine just no spin. I was able to, after installing the new parts, get the spin to work just once. When I stopped the spin and moved the timer knob to try to recreate the spin, nothing happened. The tub is locked in place. At installation I was able the spin the tub freely in both directions, but now, just as before, I can’t turn the tub by hand in the spin mode. I’m very frustrated and I know this is a simple problem that I will end up paying a repairman to fix. Please HELP before I have to resort to that.
