I found a burned transistor on the master control board and need to know what other components I need to check out so I don't blow the replacement board when I install it. The transistor is the one in the second row from the bottom just to the left of C-19 directly above the rightmost pin on the P7 connector
Thank you
RonSr
This is almost always caused by the failure of the wax motors that . Change them out with the new board and you should be fine.
Originally Posted by: sidfink43 This is almost always caused by the failure of the wax motors that . Change them out with the new board and you should be fine. Thanks for the tip
