When I have only the cold water hose hooked up to my washer and turn it on, the washer fills slowly, and water comes out of the hot water hose....
Is this normal...
You need both hoses connected or water will move from one to the other because there is not water pressure. Even if you don't have a hot water source, you still need a hose connected and pressurized.
