My washer will not spin, so i checked out drain hose and intake hoses, the washer did go off balance and the code dc came did up the first and only time. so i took all the cloths out and than start the washer on a new cycle nothing in it no weight and it ran fine with no codes and completed a full wash. so we loaded it again and now it stops again before it starts the spin with out any codes. ?????????????? Please Help Kevin
Kevin, If your console looks like the Pic below then the issue is more than likely a Clutch Pulley issue.If you machine is a FAV6800A console pic below or a FAV9800A the LCD flavor of the machine then read thru this post and see if it helps; Maytag Neptune load unbalanceTry to post your model number that will help us. Right now I’m going on your failure description which is a classic failure for the Maytag TL models above………….Dickdh1200s attached the following image(s):
