Discuss
washer pump not working
 in
Washer Repair
I recently replaced the tub bearing and installed a new mounting stem repair kit. The machine worked fine for a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer pump not working
  #1 (permalink)
Old 06-17-2011, 03:23 PM
Junior Member
zalben is on a distinguished road
Default washer pump not working
Model Number: a612   Brand: Maytag   Age: More than 10 years
I recently replaced the tub bearing and installed a new mounting stem repair kit. The machine worked fine for a while and then did not spin on the spin cycle. Pump was working and it started spinning again. Today saw that flywheel was not turning during spin cycle and I smelled something electrical burning. Now pump does not work. Machine will fill with water for wash and rinse.
Fuse? Help.
Ads By Google
Related Models
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
Admiral A8241RT-L SURFACE UNIT- GAS
Admiral A8241RV SURFACE UNIT- GAS
Admiral A8241RW SURFACE UNIT- GAS
Admiral A8241RW-L SURFACE UNIT- GAS
Admiral A8261RB SURFACE UNIT- GAS
Admiral A8261RV SURFACE UNIT- GAS
Admiral A82LK-3K-R SURFACE UNIT- GAS
Admiral A82LN-3K-R SURFACE UNIT- GAS
Admiral A82LW-2K-R SURFACE UNIT- GAS
Admiral A8321PA SURFACE UNIT- GAS
Admiral A8321PS SURFACE UNIT- GAS
Admiral A8321PW SURFACE UNIT- GAS
Admiral A8321TA-L SURFACE UNIT- GAS
Admiral A8321TW-L SURFACE UNIT- GAS
Maytag A8340 WASHER-TOP LOADING
Maytag A8420 WASHER-TOP LOADING
Maytag A8440 WASHER-TOP LOADING
Maytag A8500 WASHER-TOP LOADING
Maytag A8520 WASHER-TOP LOADING
Maytag A8600 WASHER-TOP LOADING
Admiral A8610PA SURFACE UNIT- ELE
Admiral A8610PS SURFACE UNIT- ELE
Admiral A8610PV SURFACE UNIT- ELE
Maytag A8640 WASHER-TOP LOADING
Maytag A8650 WASHER-TOP LOADING
Admiral A8670PB SURFACE UNIT- ELE
Admiral A8670PV SURFACE UNIT- ELE
Admiral A86LW-1-R SURFACE UNIT- ELE
Maytag A8700 WASHER-TOP LOADING
Admiral A8720PA SURFACE UNIT- ELE
Admiral A8720PW SURFACE UNIT- ELE
Maytag A8740 WASHER-TOP LOADING
Maytag A8800 WASHER-TOP LOADING
Maytag A882 WASHER-TOP LOADING
Maytag A8820 WASHER-TOP LOADING
Maytag A883 WASHER-TOP LOADING
Maytag A884 WASHER-TOP LOADING
Maytag A8840 WASHER-TOP LOADING
Admiral A88FK-1 SURFACE UNIT- ELE
Admiral A88FK-2-R SURFACE UNIT- ELE
Admiral A88FK-6-R SURFACE UNIT- ELE
Admiral A88FN-2-R SURFACE UNIT- ELE
Admiral A88FN-2R SURFACE UNIT- ELE
Admiral A88LK-6-R SURFACE UNIT- ELE
Admiral A88LN-6-R SURFACE UNIT- ELE
Admiral A89L-4-R SURFACE UNIT- ELE
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
Frigidaire A8MECUSC2 Frg(v6) / Room Air Conditioner
Frigidaire A8MECUSC3 Frg(v7) / Room Air Conditioner
Maytag A8RXCGFXS00 REFRIGERATOR
Maytag A8RXCGFXS01 REFRIGERATOR
Maytag A8RXCGFXW00 REFRIGERATOR
Maytag A8RXCGFXW01 REFRIGERATOR
Maytag A8RXNGFXD00 REFRIGERATOR
Maytag A8RXNGMWB00 REFRIGERATOR
Maytag A8RXNGMWB01 REFRIGERATOR
Maytag A8RXNGMWD00 REFRIGERATOR
  #2 (permalink)
Old 06-18-2011, 03:02 AM
Junior Member
Default washer
OK. must be a thermal switch. Pump works. Now I need to know what to do about the flywheel not turning
Reply
« Silvio | Washer »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
W/W washer won't pump mrt Washer Repair 3 03-20-2010 01:20 PM
Neptune washer spins and pump working but clothes still wet lanehi Washer Repair 1 10-26-2009 06:56 AM
washer pump mom01 Washer Repair 7 03-29-2009 08:50 AM
Bosch washer pump issue (already replaced pump!) wdt Washer Repair 0 12-02-2008 06:26 AM
Is it the Washer Pump aorose Washer Repair 1 10-27-2007 10:01 AM
