My Washer Will Not Stop Filling With Water No Matter What Water Level I Set It At.
Originally Posted by: PATTI M My Washer Will Not Stop Filling With Water No Matter What Water Level I Set It At. Patti, How do you stop the washer fill, If you have to turn the faucets off at the wall, You'll need to replace the fill valve, Part number: AP4024482
If you have to unplug the power cord or turn the washer off, to stop the fill, You'll need to check or replace the water level switch and airdome hose. Part number: AP4025680
Part number: AP4025726
If the hose has a hole , is kinked or clogged it will not activate the water level switch. Good Luck, :) :) :)
