Discuss
PULL to start: no water. PUSH to stop: WATER!
 in
Washer Repair
My top loading whirlpool washer machine started acting weird tonight. Usually when I PULL the timer knob, water will release
Appliance Repair Forum > Appliance Repair Help > Washer Repair » PULL to start: no water. PUSH to stop: WATER!
  #1 (permalink)
Old 06-16-2011, 08:12 PM
Junior Member
gatsby is on a distinguished road
Question PULL to start: no water. PUSH to stop: WATER!
Model Number: eh..I don't that info atm   Brand: Whirlpool   Age: 1 - 5 years
Usually when I PULL the timer knob, water will release but tonight when I PULL the knob, there was no water filling the reservoir.
I PUSHED in the knob so I can restart the process but before I had even PUSHED the timer knob all the way back, the water comes out!
Problem is, I have to manually stand there and hold it with a certain pressure for the water to fill the washer.
If I PULL the timer knob all the way out...it does not fill.
If I PUSH the timer knob all the way back...it does not fill.
..it's like in between, then I will see water.
I do not know what the problem is in order to start looking for answers.
The timer? The lid switch?
Everything else works fine (it drains, it spins, it washes - all okay).
Just the timer knob + the filling of the water (in both wash & rinse cycle).
Please help! Thank you for reading & your advice!
Ads By Google
Related Models
Whirlpool EH050FXAN00
Whirlpool EH050FXDN00
Whirlpool EH050FXEN00
Whirlpool EH050FXEN01
Whirlpool EH050FXEN02
Whirlpool EH050FXGW00
Whirlpool EH050FXGW01
Whirlpool EH050FXGW02
Whirlpool EH050FXGW03
Whirlpool EH050FXGW04
Whirlpool EH050FXGW05
Whirlpool EH050FXGW06
Whirlpool EH050FXGW07
Whirlpool EH050FXGW08
Whirlpool EH050FXJW00
Whirlpool EH050FXJW01
Whirlpool EH050FXKQ00
Whirlpool EH050FXKQ01
Whirlpool EH050FXMQ00 Chest Freezer
Whirlpool EH050FXMQ01 Chest Freezer
Whirlpool EH050FXMQ02 Chest Freezer
Whirlpool EH050FXMQ03 Chest Freezer
Whirlpool EH050FXMQ04 Chest Freezer
Whirlpool EH050FXRQ00 Chest Freezer
Whirlpool EH050FXRQ01 Chest Freezer
Whirlpool EH050FXVN00
Whirlpool EH060FXKN5
Whirlpool EH060FXLN5
Whirlpool EH060FXPN5
Whirlpool EH060FXPN6
Whirlpool EH060FXPN7
Whirlpool EH060FXSN00
Whirlpool EH060FXSW00
Whirlpool EH06EFXPW07
Whirlpool EH06EFXPW5
Whirlpool EH070CFXCQ00 Chest Freezer
Whirlpool EH070FXAN00
Whirlpool EH070FXDN00
Whirlpool EH070FXEN00
Whirlpool EH070FXEN01
Whirlpool EH070FXEN06
Whirlpool EH070FXGW00
Whirlpool EH070FXGW01
Whirlpool EH070FXGW05
Whirlpool EH070FXGW06
Whirlpool EH070FXJW00
Whirlpool EH070FXJW01
Whirlpool EH070FXKQ00
Whirlpool EH070FXKQ01
Whirlpool EH070FXMQ00 Chest Freezer
Whirlpool EH070FXMQ01 Chest Freezer
Whirlpool EH070FXRQ00 Chest Freezer
Whirlpool EH070FXVN00
Whirlpool EH090FXKN0
Whirlpool EH090FXKN2
Whirlpool EH090FXLN2
Whirlpool EH090FXLN5
Whirlpool EH090FXPN5
Whirlpool EH090FXSN00
Whirlpool EH090FXSN10
Whirlpool EH090FXSW00
Whirlpool EH090FXSW10
Whirlpool EH09EFXPW07
Whirlpool EH09EFXPW5
Whirlpool EH09EFXPW6
Whirlpool EH09EFXPW7
Whirlpool EH100FXAN00
Whirlpool EH100FXDN00
Whirlpool EH100FXEN00
Whirlpool EH100FXEN06
Whirlpool EH100FXGW00
Whirlpool EH100FXGW01
Whirlpool EH100FXGW05
Whirlpool EH100FXGW06
Whirlpool EH100FXJW00
Whirlpool EH100FXJW01
Whirlpool EH100FXKQ00
Whirlpool EH100FXKQ01 Chest Freezer
Whirlpool EH100FXVN00
Whirlpool EH101FXMQ00 Chest Freezer
Whirlpool EH101FXMQ01 Chest Freezer
Whirlpool EH101FXRQ00 Chest Freezer
Whirlpool EH120CXLW5
Whirlpool EH120CXLW6
Whirlpool EH120CXLW7
Whirlpool EH120CXPW5
Whirlpool EH120FXKQ00
Whirlpool EH120FXSN00
Amana EH13A1 Commercial Microwaves
Whirlpool EH1500XPM5
Whirlpool EH150CXKW2
Whirlpool EH150CXLW2
Whirlpool EH150CXLW3
Whirlpool EH150CXPW5
Whirlpool EH150CXSW00
Whirlpool EH150FXAN00
Whirlpool EH150FXDN00
Whirlpool EH150FXEN00
Whirlpool EH150FXEN01
Whirlpool EH150FXEN03
Whirlpool EH150FXEN04
Whirlpool EH150FXEN06
Whirlpool EH150FXGW00
Whirlpool EH150FXGW02
Whirlpool EH150FXGW05
Whirlpool EH150FXGW06
Whirlpool EH150FXJW00
Whirlpool EH150FXKN2
Whirlpool EH150FXKQ00
Whirlpool EH150FXKQ01 Chest Freezer
Whirlpool EH150FXLN2
Whirlpool EH150FXLN3
Whirlpool EH150FXMQ00 Chest Freezer
Whirlpool EH150FXMQ01 Chest Freezer
Whirlpool EH150FXPN2
Whirlpool EH150FXPN5
Whirlpool EH150FXRQ00 Chest Freezer
Whirlpool EH150FXSN00
Whirlpool EH150FXTN00
Whirlpool EH150FXVN00
  #2 (permalink)
Old 06-17-2011, 12:37 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Gatsby,
You most likely have a bad contact inside the timer mechanism.
Start by replacing the timer assembly.
Without a model number, we can't assist with part numbers or service information.
But,You may be able to work with this information:
Servicing Components in the Console
1. Remove the two Phillips-head screws securing the front corners of the console to the washer top.
2. Tip the console back on the hinges that secure the top of the console to the washer back.
Removing the Timer
There are two types of timers. One can be identified by a plastic body. The other has a metal body.
Plastic Body
NOTE: DO NOT ATTEMPT TO REMOVE THE TIMER KNOB BY PULLING FROM
THE FRONT. Doing so will damage the split shaft and require replacing the
entire timer assembly.
1. To remove the timer knob, push the knob in from the front.
2. At the back of the timer, pull the black tab out approximately 3/16", then pull the timer knob off the shaft.
3. Slide the timer dial from the timer hub.
4. Unplug the wiring harness connector from the timer assembly terminals.
5. Remove the one (1) Hex-head screw securing the left side of the timer assembly to the console mounting plate. Then lift the left side and slide the tabs at the right side of the timer assembly from the console mounting plate.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-17-2011, 10:58 PM
Junior Member
Default
Thank you for response Joe!
I will follow the directions that was given and report back on the situation.
Thanks again for helping me pinpointing the problem!
  #4 (permalink)
Old 06-20-2011, 06:20 AM
Senior Expert
Default
Gatsby,
Good deal,
Hope to hear from you soon.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Pull Start / Push Stop Knob comes OFF! jbueker Washer Repair 10 09-15-2010 06:34 PM
Dehumidifier Runs - but won't pull water rls1969 Heating, Ventilation, and Air Conditioning (HVAC) 0 10-16-2009 05:45 AM
Condenser fan - Push or Pull air? GTX1564 Refrigerator & Freezer Repair 3 10-13-2009 04:55 PM
Removing Push Pull Button gmc250f Washer Repair 3 03-24-2009 05:48 AM
Help My Neptune will not pull water out of clothes?? ABBY Washer Repair 2 09-28-2008 12:58 PM
