Discuss
replacing Kenmore Washer power cord to ground it, change angle of cord
 in
Washer Repair
I have a Kenmore washer with a power cord that has the grounding prong on the outlet plug MISSING so
Appliance Repair Forum > Appliance Repair Help > Washer Repair » replacing Kenmore Washer power cord to ground it, change angle of cord
  #1 (permalink)
Old 06-15-2011, 11:46 AM
Junior Member
maddy is on a distinguished road
Default replacing Kenmore Washer power cord to ground it, change angle of cord
Model Number: KAWE560WWH3   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore washer with a power cord that has the grounding prong on the outlet plug MISSING so it is not grounded! The washer works FINE, but I want it safe, grounded. Also the plug's cord now is 90 degrees, down and interferes with the dryer (GE space saver 120V 15 amp 3 prong standard plug, not a "dryer plug" ) so they can't be plugged into the same outlet!! So I need to :
1. Replace the washer plug with a new cord that comes straight out (versus downwards) with grounding!!
2. Make sure it is going to work, fit the terminal slide-in at the back of the washer.
Not that the in-kind expensive "kenmore washer " cord replacement has a plastic end piece with the 3 wire terminal in a wider translucent white block (terminal end, not the recepticle end) see http://www.appliancepartspros.com/Appliance-Parts/whirlpool-power-cord-item-number-ap3138837.aspx .
I found was a whirlpool/kenmore replacement that has the cord coming out the plug (not at 90 degrees). It is much cheaper but it has a 2 wire (white/black neutral/hot) and the ground wire outside of the 2 wide terminal slide-in block. It is:
Part Number: AP4027317 made by Whirlpool
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-cord--power--as-wrapped--item-number-ap4027317.aspx
Can I USE THIS one and then put the ground wire on the ground slot/terminal? How do I get this to work????
The other "standard" replacement I found elsewhere has the same green ground wire with the ring, and the 2 wire white slide in block at the end:
http://www.************************.com/PartDetail/Power-Cord/285800/3005?modelNumber=KAWE560WWH3%20%20%20%20%20%20%20% 20%20%20%20%20%20
So how do I put it the replacement power cord with the narrow slide in block, loose round wire??? HELP
Ads By Google
Related Models
Whirlpool KAWE560WWH3
Whirlpool KAWE564WAL0
Whirlpool KAWE564WAL1
Whirlpool KAWE564WAL2
Whirlpool KAWE564WAL3
Whirlpool KAWE564WWH0
Whirlpool KAWE564WWH1
Whirlpool KAWE564WWH2
Whirlpool KAWE564WWH3
Whirlpool KAWE565BAL0
Whirlpool KAWE565BWH0
Whirlpool KAWE565BWH1
Whirlpool KAWE567WWH0
Whirlpool KAWE570BAL0
Whirlpool KAWE570BAL1
Whirlpool KAWE570BWH0
Whirlpool KAWE570BWH1
Whirlpool KAWE577BWH0
Whirlpool KAWE577BWH1
Whirlpool KAWE578BAL0
Whirlpool KAWE578BAL1
Whirlpool KAWE650VAL0
Whirlpool KAWE650VWH0
Whirlpool KAWE660WAL0
Whirlpool KAWE660WAL1
Whirlpool KAWE660WAL2
Whirlpool KAWE660WAL3
Whirlpool KAWE660WWH0
Whirlpool KAWE660WWH1
Whirlpool KAWE660WWH2
Whirlpool KAWE660WWH3
Whirlpool KAWE665BAL0
Whirlpool KAWE665BWH0
Whirlpool KAWE667BWH0
Whirlpool KAWE667BWH1
Whirlpool KAWE668BAL0
Whirlpool KAWE668BAL1
Whirlpool KAWE670BAL0
Whirlpool KAWE670BWH0
Whirlpool KAWE670BWH1
Whirlpool KAWE677BWH0
Whirlpool KAWE677BWH1
Whirlpool KAWE678BAL0
Whirlpool KAWE678BAL1
Whirlpool KAWE679BBL0
Whirlpool KAWE679BBL1
Whirlpool KAWE700TWH0
Whirlpool KAWE742BAL0
Whirlpool KAWE742BWH0
Whirlpool KAWE742VAL0
Whirlpool KAWE742VWH0
Whirlpool KAWE742WAL0
Whirlpool KAWE742WAL1
Whirlpool KAWE742WAL2
Whirlpool KAWE742WAL3
Whirlpool KAWE742WWH0
Whirlpool KAWE742WWH1
Whirlpool KAWE742WWH2
Whirlpool KAWE742WWH3
Whirlpool KAWE750VAL0
Whirlpool KAWE750VWH0
Whirlpool KAWE755VAL0
Whirlpool KAWE755VWH0
Whirlpool KAWE760WAL0
Whirlpool KAWE760WAL1
Whirlpool KAWE760WAL2
Whirlpool KAWE760WAL3
Whirlpool KAWE760WWH0
Whirlpool KAWE760WWH1
Whirlpool KAWE760WWH2
Whirlpool KAWE760WWH3
Whirlpool KAWE764WAL0
Whirlpool KAWE764WAL1
Whirlpool KAWE764WAL2
Whirlpool KAWE764WWH0
Whirlpool KAWE764WWH1
Whirlpool KAWE764WWH2
Whirlpool KAWE767BWH0
Whirlpool KAWE767WAL0
Whirlpool KAWE767WWH0
Whirlpool KAWE768BAL0
Whirlpool KAWE768BAL1
Whirlpool KAWE768BWH0
Whirlpool KAWE770BAL0
Whirlpool KAWE770BWH0
Whirlpool KAWE770BWH1
Whirlpool KAWE777BWH0
Whirlpool KAWE777BWH1
Whirlpool KAWE778BAL0
Whirlpool KAWE778BAL1
Whirlpool KAWE800SWH1
Whirlpool KAWE800TWH0
Whirlpool KAWE842WAL0
Whirlpool KAWE842WAL1
Whirlpool KAWE842WAL2
Whirlpool KAWE842WWH0
Whirlpool KAWE842WWH1
Whirlpool KAWE842WWH2
Whirlpool KAWE850VAL0
Whirlpool KAWE850VAL1
Whirlpool KAWE850VWH0
Whirlpool KAWE850VWH1
Whirlpool KAWE860WAL0
Whirlpool KAWE860WAL1
Whirlpool KAWE860WAL2
Whirlpool KAWE860WAL3
Whirlpool KAWE860WWH0
Whirlpool KAWE860WWH1
Whirlpool KAWE860WWH2
Whirlpool KAWE860WWH3
Whirlpool KAWE870BAL0
Whirlpool KAWE870BWH0
Whirlpool KAWE870BWH1
Whirlpool KAWE877BWH1
Whirlpool KAWE878BAL1
Whirlpool KAWE900SWH1
Whirlpool KAWE900SWH2
Whirlpool KAWE900TWH0
Whirlpool KAWE900TWH1
Whirlpool KAWE950VAL0
  #2 (permalink)
Old 06-16-2011, 02:34 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Why not just replace the plug on the line cord instead of the line cord.
Replacement Plugs | Electrical | Building Materials | Home Depot Canada
__________________
  #3 (permalink)
Old 06-16-2011, 09:01 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Maddy,
Consider this :
Replace the washer power cord, with the correct part.
(due to the moisture/water and possible shock hazard).
Then, also replace the dryer line cord, as well.
(with one that has the straight plug).
Of course Denman's suggestion will work as well, and be a lot less expensive.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? maddy Washer Repair 1 06-17-2011 04:36 PM
Replacing Maytag portable dishwasher power cord TML73 Dishwasher Repair 1 11-28-2010 01:47 AM
power cord pulled loose from kenmore michael hieronymus Refrigerator & Freezer Repair 0 09-08-2009 02:15 PM
how do I change the power cord on Whirlpool dryer? mpurvance Dryer Repair 1 08-02-2009 07:32 AM
Stackable washer power cord replacement dougstevens Washer Repair 1 12-06-2007 05:00 PM
