Discuss
No spin or agitate, pump ok, black grit under washer
 in
Washer Repair
After much noise and grinding, the washer has stopped spinning or agitating. The pump and motor are working fine. When
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No spin or agitate, pump ok, black grit under washer
  #1 (permalink)
Old 06-15-2011, 07:18 AM
Junior Member
batkins61 is on a distinguished road
Default No spin or agitate, pump ok, black grit under washer
Model Number: LSV7244AQ0   Brand: Whirlpool   Age: 5 - 10 years
After much noise and grinding, the washer has stopped spinning or agitating. The pump and motor are working fine. When I moved the washer, there was a small pile of black dust/grit under the washer (maybe a half-cup or so) and a small spot of oil (maybe a tablespoon or two).
At first I was thinking transmission, but looking at the parts diagram for the internals of he transmission, I don't see a whole lot of black parts (at least those with pictures). I also had a transmission fail on a previous washer long ago, and it dumped about a quart of oil. So now I suspect the motor/transmission coupling.
Before I separate the motor and the transmission and try to verify what's wrong, I wanted to get opinions on what the likely problem is, if possible, given what I've seen. Any help would be most welcome.
Thanks!
Ads By Google
Related Models
Whirlpool LSV7244AQ0
Whirlpool LSV7244AW0
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0
Whirlpool LSV8244BQ0
Whirlpool LSV8244BW0
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Maytag LSW24A Ref - SXS/I&W
Whirlpool LSW9245EQ0
Whirlpool LSW9245EQ1
Whirlpool LSW9245EQ2
Whirlpool LSW9700PQ0 Automatic Washer
Whirlpool LSW9700PQ1 Automatic Washer
Whirlpool LSW9700PQ2 Automatic Washer
Whirlpool LSW9750PW0 Automatic Washer
Whirlpool LSW9750PW1 Automatic Washer
Whirlpool LSW9750PW2 Automatic Washer
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
Frigidaire LT250JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT250JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT250JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT250JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT250LXD1 Wwh(v5) / Tumble Action Washer
Frigidaire LT250LXH1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250LXW1 Wwh(v4) / Tumble Action Washer
Frigidaire LT350RXD1 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT350RXW1 Wwh(v1) / 27 " Front Load Washer
Whirlpool LT4900XMW0
Whirlpool LT4900XMW1
Whirlpool LT4900XMW2
Whirlpool LT4900XSW1
Whirlpool LT4900XSW2
Whirlpool LT4900XSW3
Whirlpool LT4905XMW0
Whirlpool LT5000XLW0
Whirlpool LT5000XMW0
Whirlpool LT5000XMW1
Whirlpool LT5000XSW1
Whirlpool LT5000XSW2
Whirlpool LT5000XSW3
Whirlpool LT5000XVN0
Whirlpool LT5000XVW0
Whirlpool LT5004XMW0
Whirlpool LT5004XMW1
Whirlpool LT5004XSW1
Whirlpool LT5004XSW2
Whirlpool LT5004XSW3
Whirlpool LT5004XVN0
Whirlpool LT5004XVW0
Whirlpool LT5005XMW0
Whirlpool LT5009XMW0
Whirlpool LT5100XSW0
Whirlpool LT5100XSW1
Whirlpool LT5100XVN0
Whirlpool LT5100XVW0
Frigidaire LT600EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT600EXF1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600EXF4 Wwh(v4) / Tumble Action Washer
Frigidaire LT600EXH1 Wwh(v5) / Tumble Action Washer
Frigidaire LT600EXH4 Wwh(v6) / Tumble Action Washer
Frigidaire LT600EXV1 Wwh(v7) / Tumble Action Washer
Frigidaire LT600EXV4 Wwh(v8) / Tumble Action Washer
Frigidaire LT600EXW1 Wwh(v9) / Tumble Action Washer
Frigidaire LT600EXW4 Wwh(v10) / Tumble Action Washer
__________________
There's someone in my head, but it's not me.
-- P. Floyd
  #2 (permalink)
Old 06-15-2011, 08:27 AM
gabe_1981's Avatar
Senior Expert
APP Volunteer
gabe_1981 is on a distinguished road
Default
Sounds like a motor coupling to me ... heres a video that may help
YouTube - ‪Washing Machine Drive Motor Coupler Replacement (part #285753A)‬‏
Part Info Availability Purchase enlarge photo
Whirlpool Direct Drive Washer Motor Coupling - New design! Re-enforced with metal sleeves. The coupler is located between motor and transmission. Replaces all previous versions. Fits ALL Whirlpool, Kenmore, Roper and KitchenAid direct drive washers (no belt).
Part Number: AP3963893
made by WHIRLPOOL
Our Price: $10.62
Reg. retail: $22.30
You Save: $11.68
More Info
In Stock
Order now and it will ship Today
Read more: Motor Coupling - Order Now, Same Day Shipping
Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
__________________
Case Appliance Repair College Station,Texas-
  #3 (permalink)
Old 06-15-2011, 09:09 AM
Junior Member
Default
Thanks! Awesome video! How can I check that the coupling is the only problem? In other words, of something else caused the coupling to fail, how can I diagnose that?
__________________
-- P. Floyd
  #4 (permalink)
Old 06-15-2011, 09:16 AM
gabe_1981's Avatar
Senior Expert
APP Volunteer
Default
These couplings just fail from use ... Usually no other reason ... I've replaced thousands of them and will replace thousands more in the years to come ... Glad I could help
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana machine will not spin or agitate - black furry stuff! _SanDiego_ Washer Repair 2 11-23-2009 08:06 PM
Washer will not agitate but will pump and spin wor96 Washer Repair 6 08-02-2009 01:30 PM
Replaced pump. Spin yes, agitate no. bakjar Washer Repair 2 03-09-2009 05:06 PM
kenmore 70 series washer will not agitate/spin + rusty drive shaft/pump pkme Washer Repair 2 01-27-2009 07:55 AM
Roper washer will not spin, agitate, pump litexp2 Washer Repair 16 09-26-2008 12:53 PM
