| » Whirlpool deut leaking |
Model Number: W10071760B Brand: Whirlpool Age: 1 - 5 years
My whirlpool duet washer is leaking from the bottom. I have removed the door and discovered the big black hose that goes from the soap dispenser into the tub is disconnected. It actually looks torn in the area where it connects to the tub. (Like the washer part of it is broken). Anyone know which part number the hose would be?
Thanks! Ads By Google Related Models |
Quote:
A proper model number would have been more help, Here are some parts you may need based on your basic description, if the hose is attached to the dispenser and attaches to the outer tub assembly a few inches back from the tub cover(front of tub) this should be the hose you may need, Part number: AP3128822 If it attaches to the dispenser and then attaches to the tub cover, where the water enters the tub and washes over the door glass,these parts will work. Part number: AP3128707 Part number: AP3128707 Part number: AP3128709 I'm not sure if you had something stuck between the tubs or an on going off balanced load issue. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Since the hose is an "air Vent, and is located on the top of the tub, it is basically a "friction fit". Grasp the hose as close to the tub as possible, squeeze the hose together with you fingers, pull up and work the hose out of the opening. To install the new hose, reverse the process, (A drop or 2 of liquid detergent or soap, will help to seat the new hose in the tub opening, but not too much). Remeber, not to twist or kink the hose, when you attach it to the dispenser assembly then secure the hose with the clamp.
__________________
Quote:
Great, I guess by now, the laundry must be caught up. Thanks, Good Luck,
__________________
| Display Modes | |
| Whirlpool Door leaking | rrodgers12@woh.rr.com | Dishwasher Repair | 2 | 11-22-2009 06:56 AM |
| whirlpool leaking | jmkitson | Dishwasher Repair | 3 | 11-08-2009 02:52 PM |
| Leaking Whirlpool | spartan | Dishwasher Repair | 0 | 08-09-2009 09:25 PM |
| whirlpool washer leaking | beverlyjean | Washer Repair | 1 | 05-18-2009 01:02 PM |
| leaking whirlpool fridge | maytag bob | Refrigerator & Freezer Repair | 1 | 03-09-2009 11:03 AM |
