sears troubleshooting guide said that if the fuse on the control board is blown the board is bad.FUSE IS NOT TO PROTECT CIRCUIT???? I inspected the the speed control board . I see 2 transistors burned, broke open. ther are 6 other large semiconductors on a heat sink . identity unknown. anyone ever repaired this $160 board. why would sears use a fuse to indicate instead of protecting? appal
