Discuss
Kenmore 90 Series Wahser
 in
Washer Repair
I have a noise during the spin that sounds kind of like a whine/bearing issue. I have replaced the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 Series Wahser
  #1 (permalink)
Old 11-14-2007, 12:00 PM
cid94 cid94 is offline
Junior Member
cid94 is on a distinguished road
Default Kenmore 90 Series Wahser
Model Number: 110.26902691   Brand: Kenmore   Age: 5 - 10 years
I have a noise during the spin that sounds kind of like a whine/bearing issue. I have replaced the motor coulpler with no change. Any ideas what it could be? Everything works (all cycles).
What's the possibility this is a bearing or the gearbox? Either more prone to failing?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-14-2007, 12:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is any foreign objects stuck between the inner and the outer tubs. Also check the holes in the inner tub for the same reason.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-14-2007, 01:23 PM
Junior Member
Default
Thank you for you reply. I will check the tubs. However, this definitely sounds like a gear or bearing problem. You can hear it wind down after the spin. It's not a click as if something is in the tubs.
If it's not the tubs, how can I diagnose if it is a bearing or what?
There is no leaking or stains around the gearbox, etc.
  #4 (permalink)
Old 11-14-2007, 01:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The next you should check is a foreign objects inside the pump.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Imperial series Washer pratapgandhi Washer Repair 1 11-11-2007 01:02 PM
Maytag Quiet Series 300 Locked SSaib Dishwasher Repair 0 10-23-2007 03:07 PM
frigidaire crown series taking too long to dry angryhousewife34 Dryer Repair 1 08-30-2007 01:45 AM
Kenmore 80's series not agitating leothedog Washer Repair 4 08-23-2007 10:36 PM
Kenmore 80-series washer skips spin time mac Washer Repair 1 08-14-2007 07:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
