Discuss
Water Hammer on Cold Water
 in
Washer Repair
My washer (Whirlpool model LA8800XTW0) started water hammer on the cold water only. I can stop the hammering by turning
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water Hammer on Cold Water
  #1 (permalink)
Old 06-13-2011, 08:45 PM
Junior Member
Mark4312 is on a distinguished road
Default Water Hammer on Cold Water
Model Number: LA8800XTW0   Brand: Whirlpool   Age: More than 10 years
My washer (Whirlpool model LA8800XTW0) started water hammer on the cold water only. I can stop the hammering by turning the washer off and back on quickly, but it will hammer again the next time it calls for cold water in the cycle. The cold water flow is also fluctuating, filling slower than normal while the hammering occurs, but flowing normally when there is no hammer. Does this sound like a bad water inlet valve since the flow and hammer occur at the same time?
Related Models
Whirlpool LA8800XTW0
Whirlpool LA8800XTW1
Maytag LA882 WASHER-TOP LOADING
Maytag LA8820 WASHER-TOP LOADING
Maytag LA883 WASHER-TOP LOADING
Maytag LA884 WASHER-TOP LOADING
Maytag LA8840 WASHER-TOP LOADING
Whirlpool LA8860XWQ0
Whirlpool LA9100XTF0
Whirlpool LA9100XTF1
Whirlpool LA9100XTG0
Whirlpool LA9100XTG1
Whirlpool LA9100XTM0
Whirlpool LA9100XTM1
Whirlpool LA9100XTN0
Whirlpool LA9100XTN1
Whirlpool LA9100XTW0
Whirlpool LA9100XTW1
Maytag LA9200 WASHER-TOP LOADING
Whirlpool LA9200XWF0
Whirlpool LA9200XWF1
Whirlpool LA9200XWG0
Whirlpool LA9200XWG1
Whirlpool LA9200XWM0
Whirlpool LA9200XWM1
Whirlpool LA9200XWN0
Whirlpool LA9200XWN1
Whirlpool LA9200XWW0
Whirlpool LA9200XWW1
Maytag LA9300 WASHER-TOP LOADING
Whirlpool LA9300XTF0
Whirlpool LA9300XTF1
Whirlpool LA9300XTG0
Whirlpool LA9300XTG1
Whirlpool LA9300XTM0
Whirlpool LA9300XTM1
Whirlpool LA9300XTN0
Whirlpool LA9300XTN1
Whirlpool LA9300XTW0
Whirlpool LA9300XTW1
Whirlpool LA9300XYG0
Whirlpool LA9300XYN0
Whirlpool LA9300XYW0
Whirlpool LA9320XTW0
Whirlpool LA9320XTW1
Whirlpool LA9320XYW0
Maytag LA9400 WASHER-TOP LOADING
Maytag LA9400S WASHER-TOP LOADING
Maytag LA9400W WASHER-TOP LOADING
Whirlpool LA9480XWF0
Whirlpool LA9480XWF1
Whirlpool LA9480XWF2
Whirlpool LA9480XWG0
Whirlpool LA9480XWG1
Whirlpool LA9480XWG2
Whirlpool LA9480XWM0
Whirlpool LA9480XWM1
Whirlpool LA9480XWM2
Whirlpool LA9480XWN0
Whirlpool LA9480XWN1
Whirlpool LA9480XWN2
Whirlpool LA9480XWW0
Whirlpool LA9480XWW1 Washers*
Whirlpool LA9480XWW2
Whirlpool LA9500XTF0 AUTOMATIC WASHER
Whirlpool LA9500XTF1 AUTOMATIC WASHER
Whirlpool LA9500XTG0 AUTOMATIC WASHER
Whirlpool LA9500XTG1 AUTOMATIC WASHER
Whirlpool LA9500XTM0 AUTOMATIC WASHER
Whirlpool LA9500XTM1 AUTOMATIC WASHER
Whirlpool LA9500XTN0 AUTOMATIC WASHER
Whirlpool LA9500XTN1 AUTOMATIC WASHER
Whirlpool LA9500XTW0
Whirlpool LA9500XTW1
Whirlpool LA9580XWF0
Whirlpool LA9580XWF1
Whirlpool LA9580XWG0
Whirlpool LA9580XWG1
Whirlpool LA9580XWM0
Whirlpool LA9580XWM1
Whirlpool LA9580XWN0
Whirlpool LA9580XWN1
Whirlpool LA9580XWW0
Whirlpool LA9580XWW1
Maytag LA9600 WASHER-TOP LOADING
Whirlpool LA9680XWF0
Whirlpool LA9680XWF1
Whirlpool LA9680XWG0
Whirlpool LA9680XWG1
Whirlpool LA9680XWM0
Whirlpool LA9680XWM1
Whirlpool LA9680XWN0
Whirlpool LA9680XWN1
Whirlpool LA9680XWW0
Whirlpool LA9680XWW1
Maytag LA9700 WASHER-TOP LOADING
Maytag LA9700S WASHER-TOP LOADING
Maytag LA9700W WASHER-TOP LOADING
Maytag LA9800 WASHER-TOP LOADING
Whirlpool LA9800XKW1
Whirlpool LA9800XKW2
Whirlpool LA9800XMW0
Whirlpool LA9800XPW0
Whirlpool LA9800XPW1
Whirlpool LA9800XSN1 AUTOMATIC WASHER
Whirlpool LA9800XSN2 AUTOMATIC WASHER
Whirlpool LA9800XSW1
Whirlpool LA9800XSW2
Whirlpool LA9800XTF0 AUTOMATIC WASHER
Whirlpool LA9800XTF1 AUTOMATIC WASHER
Whirlpool LA9800XTG0 AUTOMATIC WASHER
Whirlpool LA9800XTG1 AUTOMATIC WASHER
Whirlpool LA9800XTM0 AUTOMATIC WASHER
Whirlpool LA9800XTM1 AUTOMATIC WASHER
Whirlpool LA9800XTN0 AUTOMATIC WASHER
Whirlpool LA9800XTN1 AUTOMATIC WASHER
Whirlpool LA9800XTW0
Whirlpool LA9800XTW1
Maytag LA9900 WASHER-TOP LOADING
Whirlpool LAB2700LK0 PEDESTAL
  #2 (permalink)
Old 06-15-2011, 04:32 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hammering comes from air in the lines. Clean out the line from the water valve forward and see if that helps. If not, you can try replacing the valve assembly.
__________________
  #3 (permalink)
Old 06-16-2011, 12:32 PM
Junior Member
Default Installed New Valve - Issue Resolved.
In the interest of time, I installed a new water inlet valve before trying anything else, and it fixed the problem. It would have been a much more difficult task if I hadnít watched this video that shows how to do everything, step by step.
http://youtu.be/Fk4puRv3Vk8
  #4 (permalink)
Old 06-16-2011, 03:24 PM
Senior Expert
APP Volunteer
Default
Great, glad you found that video and go it fixed.
Thanks also for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile leaking water for cold water supply into drum when not in use venicebeachvillas Washer Repair 4 12-08-2011 06:06 AM
Water Hammer Pipes after filling glennonr Washer Repair 0 04-12-2010 07:53 PM
Cold water, hot water flow BEC75 Washer Repair 1 07-02-2008 10:36 PM
Cold water in warm water settings Douglas Doty Washer Repair 1 06-03-2008 09:12 AM
Whirlpool LA5300XM Cold water trickles, warm water flows properly ajaysheetal Washer Repair 2 02-14-2008 04:49 PM
