Whirlpool removal of 7/16 screw
The top agitator ( clothes mover) has a 7/16 bolt that has to be removed in order to remove top agitator. I have tried to turn it but bottom agitor turns and I cannot break bolt loose. Any suggestions will be appreciated
Tight Bolt
Quote:
Get someone to hold the bottom of the agitator and loosten the bolt. If very hard to turn, be carefull not to bust it. I usually turn it a bit then spray WD- 40 on it and turn it back and forth till it frees up. Avoid using a break out bar on it, you might sheer it off in the tranny spindle.
| All times are GMT -7. The time now is 02:04 PM. |
