Discuss
Whirlpool duet doesn't drain intermittently
 in
Washer Repair
A few weeks ago, my Whirlpool duet washer stopped draining fulling - it would resolve itself if you ran an
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool duet doesn't drain intermittently
  #1 (permalink)
Old 06-12-2011, 06:48 PM
Junior Member
aj76 is on a distinguished road
Default Whirlpool duet doesn't drain intermittently
Model Number: GHW9150PW0   Brand: Whirlpool   Age: 1 - 5 years
A few weeks ago, my Whirlpool duet washer stopped draining fulling - it would resolve itself if you ran an extra 'spin/drain' cycle. The problem has gotten worse and it now won't fully drain a lot of the time.
I've tested a few things and can't quite figure out what's going on. The drain hose isn't kinked, etc. and I've cleaned out the drain tube from the tub to the pump and checked as much of the tube from the pump out that I could.
Using info in the service manual (http://www.applianceblog.com/manuals/DuetWasher.pdf), I tested the continuity of the pressure switch, since I read that it will drain until the pressure switch tells the CCU that its 'empty'. I noticed that the continuity when the washer has stopped with water still in it is 0 ohms for 2 sets of pins - 4 & 5 to indicate "L1" and 1 & 2 to indicated "SUDS". I've never seen the SUDS error code come up and see these two pins behave this way even when the tub is empty (and pins 4 & 6 are 'active' as they should be). Is it possible my pressure switch is bad and confusing the CCU? Does it make sense to buy a new one or try to 'clean' the existing one as I've read they can get clogged.
Any help is much appreciated.
Thanks.
Related Models
Whirlpool GHW9150PW0 AUTOMATIC WASHER
Whirlpool GHW9150PW1 AUTOMATIC WASHER
Whirlpool GHW9150PW2 AUTOMATIC WASHER
Whirlpool GHW9150PW3 AUTOMATIC WASHER
Whirlpool GHW9150PW4 AUTOMATIC WASHER
Whirlpool GHW9160PW0 AUTOMATIC WASHER
Whirlpool GHW9160PW1 AUTOMATIC WASHER
Whirlpool GHW9160PW2 AUTOMATIC WASHER
Whirlpool GHW9160PW3 AUTOMATIC WASHER
Whirlpool GHW9160PW4 AUTOMATIC WASHER
Whirlpool GHW9200LQ0 WASHER
Whirlpool GHW9200LW0 WASHER
Whirlpool GHW9250ML0 AUTOMATIC WASHER
Whirlpool GHW9250ML1 AUTOMATIC WASHER
Whirlpool GHW9250ML2 AUTOMATIC WASHER
Whirlpool GHW9250MQ0 AUTOMATIC WASHER
Whirlpool GHW9250MQ1 AUTOMATIC WASHER
Whirlpool GHW9250MQ2 AUTOMATIC WASHER
Whirlpool GHW9250MT0 AUTOMATIC WASHER
Whirlpool GHW9250MT1 AUTOMATIC WASHER
Whirlpool GHW9250MT2 AUTOMATIC WASHER
Whirlpool GHW9250MW0 AUTOMATIC WASHER
Whirlpool GHW9250MW1 AUTOMATIC WASHER
Whirlpool GHW9250MW2 AUTOMATIC WASHER
Whirlpool GHW9300PW0 AUTOMATIC WASHER
Whirlpool GHW9300PW1 AUTOMATIC WASHER
Whirlpool GHW9300PW2 AUTOMATIC WASHER
Whirlpool GHW9300PW3 AUTOMATIC WASHER
Whirlpool GHW9300PW4 AUTOMATIC WASHER
Whirlpool GHW9400PL0 AUTOMATIC WASHER
Whirlpool GHW9400PL1 AUTOMATIC WASHER
Whirlpool GHW9400PL2 AUTOMATIC WASHER
Whirlpool GHW9400PL3 AUTOMATIC WASHER
Whirlpool GHW9400PL4 AUTOMATIC WASHER
Whirlpool GHW9400PT0 AUTOMATIC WASHER
Whirlpool GHW9400PT1 AUTOMATIC WASHER
Whirlpool GHW9400PT2 AUTOMATIC WASHER
Whirlpool GHW9400PT3 AUTOMATIC WASHER
Whirlpool GHW9400PT4 AUTOMATIC WASHER
Whirlpool GHW9400PW0 AUTOMATIC WASHER
Whirlpool GHW9400PW1 AUTOMATIC WASHER
Whirlpool GHW9400PW2 AUTOMATIC WASHER
Whirlpool GHW9400PW3 AUTOMATIC WASHER
Whirlpool GHW9400PW4 AUTOMATIC WASHER
Whirlpool GHW9400SU0 AUTOMATIC WASHER
Whirlpool GHW9460PL0 AUTOMATIC WASHER
Whirlpool GHW9460PL1 AUTOMATIC WASHER
Whirlpool GHW9460PL2 AUTOMATIC WASHER
Whirlpool GHW9460PL3 AUTOMATIC WASHER
Whirlpool GHW9460PL4 AUTOMATIC WASHER
Whirlpool GHW9460PW0 AUTOMATIC WASHER
Whirlpool GHW9460PW1 AUTOMATIC WASHER
Whirlpool GHW9460PW2 AUTOMATIC WASHER
Whirlpool GHW9460PW3 AUTOMATIC WASHER
Whirlpool GHW9460PW4 AUTOMATIC WASHER
General Electric GHWP1000M0WW WASHER
General Electric GHWP1000M1WW WASHER
Whirlpool GHWT160JXX0 HOT WATER DISPENSER
Whirlpool GI0FSAXVA00 REFRIGERATOR
Whirlpool GI0FSAXVA01 REFRIGERATOR
Whirlpool GI0FSAXVB00 REFRIGERATOR
Whirlpool GI0FSAXVB01 REFRIGERATOR
Whirlpool GI0FSAXVB02 REFRIGERATOR
Whirlpool GI0FSAXVB03 REFRIGERATOR
Whirlpool GI0FSAXVB04 REFRIGERATOR
Whirlpool GI0FSAXVB05 REFRIGERATOR
Whirlpool GI0FSAXVB06 REFRIGERATOR
Whirlpool GI0FSAXVB07 REFRIGERATOR
Whirlpool GI0FSAXVQ00 REFRIGERATOR
Whirlpool GI0FSAXVQ01 REFRIGERATOR
Whirlpool GI0FSAXVY00 REFRIGERATOR
Whirlpool GI0FSAXVY01 REFRIGERATOR
Whirlpool GI0FSAXVY02 REFRIGERATOR
Whirlpool GI0FSAXVY03 REFRIGERATOR
Whirlpool GI0FSAXVY04 REFRIGERATOR
Whirlpool GI0FSAXVY05 REFRIGERATOR
Whirlpool GI0FSAXVY06 REFRIGERATOR
Whirlpool GI0FSAXVY07 REFRIGERATOR
Whirlpool GI0FSAXVY08 REFRIGERATOR
Whirlpool GI1500PHB0 ICE CUBE MAKER
Whirlpool GI1500PHB2 ICE CUBE MAKER
Whirlpool GI1500PHB3 ICE MAKER - FREESTANDING
Whirlpool GI1500PHB4 ICE CUBE MAKER
Whirlpool GI1500PHB5 ICE CUBE MAKER
Whirlpool GI1500PHB6 ICE CUBE MAKER
Whirlpool GI1500PHB7 ICE CUBE MAKER
Whirlpool GI1500PHB8 ICE CUBE MAKER
Whirlpool GI1500PHW0 ICE CUBE MAKER
Whirlpool GI1500PHW2 ICE CUBE MAKER
Whirlpool GI1500PHW3 ICE MAKER - FREESTANDING
Whirlpool GI1500PHW4 ICE CUBE MAKER
Whirlpool GI1500PHW5 ICE CUBE MAKER
Whirlpool GI1500PHW6 ICE CUBE MAKER
Whirlpool GI1500PHW7 ICE CUBE MAKER
Whirlpool GI1500PHW8 ICE CUBE MAKER
Whirlpool GI1500XHB0 ICE CUBE MAKER
Whirlpool GI1500XHB1 ICE CUBE MAKER
Whirlpool GI1500XHB2 ICE CUBE MAKER
Whirlpool GI1500XHB3 ICE CUBE MAKER
Whirlpool GI1500XHB4 ICE CUBE MAKER
Whirlpool GI1500XHB5 ICE CUBE MAKER
Whirlpool GI1500XHB6 ICE CUBE MAKER
Whirlpool GI1500XHB7 ICE CUBE MAKER
Whirlpool GI1500XHB8 ICE CUBE MAKER
Whirlpool GI1500XHB9 ICE CUBE MAKER
Whirlpool GI1500XHN0 ICE CUBE MAKER
Whirlpool GI1500XHN1 ICE CUBE MAKER
Whirlpool GI1500XHN2 ICE CUBE MAKER
Whirlpool GI1500XHN3 ICE CUBE MAKER
Whirlpool GI1500XHN4 ICE CUBE MAKER
Whirlpool GI1500XHS0 ICE CUBE MAKER
Whirlpool GI1500XHS1 ICE CUBE MAKER
Whirlpool GI1500XHS2 ICE CUBE MAKER
Whirlpool GI1500XHS3 ICE CUBE MAKER
Whirlpool GI1500XHS4 ICE CUBE MAKER
Whirlpool GI1500XHS5 ICE CUBE MAKER
Whirlpool GI1500XHS6 ICE CUBE MAKER
Whirlpool GI1500XHS7 ICE CUBE MAKER
Whirlpool GI1500XHS8 ICE CUBE MAKER
Whirlpool GI1500XHS9 ICE CUBE MAKER
  #2 (permalink)
Old 01-10-2014, 11:17 AM
Junior Member
smcdaniel8190 is on a distinguished road
Default Pump might not be getting water to pump out
After replacing the pump it still wouldn't drain. Thought about it for a couple of days, verified that the pump was working as it should and thought that it might not be getting any water.
Took off the piece coming from the bottom of the tub (where there is a ball float valve) and it was completely clogged with a HUGE hairball.
Wash, rinse, repeat -- works like brand new now.
Also might help with the mildew problems that people are talking about.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool duet won't drain CGH Washer Repair 7 01-10-2014 11:15 AM
Whirlpool Duet Will Not Drain luse241 Washer Repair 4 01-10-2014 11:14 AM
whirlpool duet washer won't drain linleason Washer Repair 33 01-10-2014 11:06 AM
Whirlpool duet won't drain GregTobin Washer Repair 1 09-24-2010 01:30 PM
Whirlpool Duet won't drain Crying over Duet Washer Repair 0 08-02-2010 05:07 AM
