Discuss
Drain cycle does not spin
 in
Washer Repair
When drain cycle begins the drum does not spin. onece I push the timer swith in and pull out the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Drain cycle does not spin
  #1 (permalink)
Old 02-26-2009, 04:15 PM
Junior Member
sbc1967 is on a distinguished road
Question Drain cycle does not spin
Model Number: lsr4100hqo   Brand: Whirlpool   Age: 5 - 10 years
When drain cycle begins the drum does not spin. onece I push the timer swith in and pull out the drum begins to spin. Was told that it was the timer switch so replaced but still does the same thing. also replaced the lid switch but same result. Any thoughts?
Related Models
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BGO WASHER
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BNO WASHER
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BQO WASHER
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
  #2 (permalink)
Old 02-27-2009, 02:43 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Timer is supposed to stop briefly during spin to allow the neutral drain tranny to engage spin mode. If no stop, you still have a bad timer.
__________________
  #3 (permalink)
Old 02-27-2009, 05:15 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
You don't think she could be possibly seeing the begining's of a clutch problem? Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
After wash cycle will not drain and spin out IndianaPanda Washer Repair 2 12-11-2009 02:01 AM
water does not drain all out on the spin cycle lavete Washer Repair 1 09-14-2009 07:31 AM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
Washer doesn't drain or go into spin cycle mrmoose Washer Repair 4 12-02-2008 10:58 AM
Washer will not drain during spin cycle tbell Washer Repair 3 11-16-2008 04:15 PM
