Machine seems to work fine for everything except agitate. I removed agitator and air bell ? if i lift up a little it seems to be engaged fine and agitate if the hold down bolt is tight agitator seems to spin. For the life of me i cant figure this out, worked just fine one load then this happened. Any thoughts or ideas greatly welcomed. Thanks all in advance. Mike Henry
