my maytag atlantis will not spin, it agitates, and pumps. any ideas?
We will probably have some but we need a model number to see exactly which machine you have.
Originally Posted by: sidfink43 We will probably have some but we need a model number to see exactly which machine you have.
Thanks My model number is mav6200aww. My email is catfaninc@yahoo.com
Ok Cat The usual suspect in these cases is the thrust bearing, this part here. Part number: AP4009132
If the transmission is turning then this will likely fix things. The instructions are included and it will help to have someone help with the repair.
