kimberley1122
#1 Posted : Wednesday, February 25, 2009 4:41:07 PM(UTC)
kimberley1122
my washer starts filling up with water.. and as soon as it starts to fill up it leaks out the bottom.. i have checked all the hoses and no leaks.. motor and pump seems to be working okay. just can't figure out where the water could be coming from? need help. mother of 4 and laundry needs to be done.:)
TechnicianBrian
#2 Posted : Wednesday, February 25, 2009 4:55:37 PM(UTC)
TechnicianBrian
Have you tried removing the cabinet and taking a look around. All water leaks should be visible so if you find water running out from under the cabinet when tub has water in it, then there is a hole someplace. Likely locations are the pump, drain hoses, or even a crack in the tub.
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 2/5/2017 1:48:24 PM(UTC)
Kenmore washer leaking water on transmission (Washer Repair)
by arttruji 6/30/2016 11:55:27 AM(UTC)
washer leaking water when washing front door (Washer Repair)
by OMAR MARTINEZ 8/13/2014 1:16:58 PM(UTC)
kitchenaid dishwasher leaking water from door (Dishwasher Repair)
by brasuca 1/20/2014 9:55:31 AM(UTC)
GE front load washer leaking water at the back of the drum. (Washer Repair)
by Ooltewah 10/13/2012 12:17:32 PM(UTC)
washer leaking water through transmission (Washer Repair)
by hessians1 1/16/2012 12:02:57 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
Dishwasher leaking water from motor area (Dishwasher Repair)
by thenefas 11/3/2010 8:25:52 PM(UTC)
Frigidaire Washer Leaking Water From Front (Washer Repair)
by sdsprigler 10/29/2010 10:27:04 AM(UTC)
Dishwasher leaking water through door (Dishwasher Repair)
by redcam80 5/8/2010 12:21:13 PM(UTC)
LG frontload washer leaking water during drain cycle (Washer Repair)
by bluefitness 1/20/2010 10:38:16 AM(UTC)
washer leaking water from bottom (Washer Repair)
by gricodrywall 12/28/2009 1:41:27 AM(UTC)
Samsung washer leaking water (Washer Repair)
by lflamenco98 9/2/2009 11:30:59 AM(UTC)
Dishwasher Leaking Water (Dishwasher Repair)
by jlehn 6/26/2009 7:41:16 AM(UTC)
washer leaking water and oil or grease on the floor under it (Washer Repair)
by asnowangel2000 4/12/2009 3:47:01 PM(UTC)
