Discuss
does not always spin
 in
Washer Repair
My washer drains but does not always spin so I have to give it a little help to go into
Appliance Repair Forum > Appliance Repair Help > Washer Repair » does not always spin
  #1 (permalink)
Old 11-13-2007, 01:26 PM
susansusan susansusan is offline
Junior Member
susansusan is on a distinguished road
Default does not always spin
Model Number: LSR8433KQO   Brand: Whirlpool   Age: 5 - 10 years
My washer drains but does not always spin so I have to give it a little help to go into the spin.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-14-2007, 12:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check in such situation is the drive block.
Remove the agitator and the spanner nut. Visually inspect the drive block. If it has to be replaced you will have to remove the cabinet and the inner tub.
In order to remove the spanner nut you will need a special spanner wrench.
- The part number for the spanner wrench AP3538707
- The part number for the drive block AP2905773
The drive block
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 09:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
