Discuss
maytag dryer
 in
Washer Repair
the outlet blow out in the laundry room we fix the outlet change the dryers plug but nothing happen the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag dryer
  #1 (permalink)
Old 06-10-2011, 12:17 AM
Junior Member
cmrodriguez78 is on a distinguished road
Default maytag dryer
Brand: Maytag   Age: More than 10 years
the outlet blow out in the laundry room we fix the outlet change the dryers plug but nothing happen the dryer doesn't turn on. now should i repair it or get a new one.
Ads By Google
  #2 (permalink)
Old 06-10-2011, 04:16 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
A model number may help others help you.
Also you are in the wrong forum section (Wahser Repair)
There is a dyer repair section.
Have you checked that you now have the correct power?
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
Maytag Dryer KyleHines Dryer Repair 2 03-22-2011 06:55 PM
Maytag Dryer can't get the top off dtortorich Dryer Repair 1 02-17-2011 03:30 AM
maytag dryer help bowhunter1 Dryer Repair 3 11-23-2009 04:12 AM
maytag dryer krislinda Dryer Repair 1 02-24-2008 11:49 AM
