Discuss
matag washer won't fill
 in
Washer Repair
i have a maytag performa washer. i can't get the water to fill in the fill or rince cycles. just
Appliance Repair Forum > Appliance Repair Help > Washer Repair » matag washer won't fill
  #1 (permalink)
Old 06-08-2011, 06:39 PM
Junior Member
tjcilia is on a distinguished road
Default matag washer won't fill
Model Number: lat2300aae   Brand: Maytag   Age: 5 - 10 years
i have a maytag performa washer. i can't get the water to fill in the fill or rince cycles. just looking for a tip on where to start
Related Models
Maytag LAT2300AAE WASHER-TOP LOADING
Maytag LAT2300AWW WASHER-TOP LOADING
Maytag LAT2301AAE WASHER-TOP LOADING
Maytag LAT2500AAE WASHER-TOP LOADING
Maytag LAT2600AAE WASHER-TOP LOADING
Maytag LAT2910AAL WASHER-TOP LOADING
Maytag LAT2910AAW WASHER-TOP LOADING
Maytag LAT2914AAE WASHER-TOP LOADING
Maytag LAT2914AAL WASHER-TOP LOADING
Maytag LAT2914AAM WASHER-TOP LOADING
Maytag LAT2915AAE WASHER-TOP LOADING
Maytag LAT2915AAM WASHER-TOP LOADING
Maytag LAT2916AAE WASHER-TOP LOADING
Maytag LAT2916AAM WASHER-TOP LOADING
Maytag LAT2916ABE WASHER-TOP LOADING
Maytag LAT3500AAE WASHER-TOP LOADING
Maytag LAT3500AAQ WASHER-TOP LOADING
Maytag LAT3600AAE WASHER-TOP LOADING
Maytag LAT3600AAQ WASHER-TOP LOADING
Maytag LAT3910AAL WASHER-TOP LOADING
Maytag LAT3910AAW WASHER-TOP LOADING
Maytag LAT3914AAE WASHER-TOP LOADING
Maytag LAT3914AAL WASHER-TOP LOADING
Maytag LAT3914AAM WASHER-TOP LOADING
Maytag LAT4000AAW WASHER-TOP LOADING
Maytag LAT4910AAL WASHER-TOP LOADING
Maytag LAT4910AAW WASHER-TOP LOADING
Maytag LAT4914AAE WASHER-TOP LOADING
Maytag LAT4914AAL WASHER-TOP LOADING
Maytag LAT4914AAM WASHER-TOP LOADING
Maytag LAT4915AAE WASHER-TOP LOADING
Maytag LAT4915AAM WASHER-TOP LOADING
Maytag LAT4916AAE WASHER-TOP LOADING
Maytag LAT4916AAM WASHER-TOP LOADING
Maytag LAT4916ABE WASHER-TOP LOADING
Maytag LAT5000AAL WASHER-TOP LOADING
Maytag LAT5000AAW WASHER-TOP LOADING
Maytag LAT5000ABL WASHER-TOP LOADING
Maytag LAT5000ABW WASHER-TOP LOADING
Maytag LAT5004AAW WASHER-TOP LOADING
Admiral LAT5004AGW WASHER-TOP LOADING
Admiral LAT5004BGW WASHER-TOP LOADING
Maytag LAT5005AAE WASHER-TOP LOADING
Maytag LAT5005AAW WASHER-TOP LOADING
Maytag LAT5005ABW WASHER-TOP LOADING
Maytag LAT5006AAE WASHER-TOP LOADING
Admiral LAT5006AGE WASHER-TOP LOADING
Admiral LAT5006GGE WASHER-TOP LOADING
Maytag LAT5910AAL WASHER-TOP LOADING
Maytag LAT5910AAW WASHER-TOP LOADING
Maytag LAT5910BAL WASHER-TOP LOADING
Maytag LAT5910BAW WASHER-TOP LOADING
Maytag LAT5914AAE WASHER-TOP LOADING
Maytag LAT5914AAL WASHER-TOP LOADING
Maytag LAT5914AAM WASHER-TOP LOADING
Maytag LAT5916AAE WASHER-TOP LOADING
Maytag LAT5916AAM WASHER-TOP LOADING
Maytag LAT5916ABE WASHER-TOP LOADING
Maytag LAT6910AAL WASHER-TOP LOADING
Maytag LAT6910AAW WASHER-TOP LOADING
Maytag LAT6914AAE WASHER-TOP LOADING
Maytag LAT6914AAL WASHER-TOP LOADING
Maytag LAT6914AAM WASHER-TOP LOADING
Maytag LAT7300AAL WASHER-TOP LOADING
Maytag LAT7300AAW WASHER-TOP LOADING
Maytag LAT7300ABL WASHER-TOP LOADING
Maytag LAT7300ABW WASHER-TOP LOADING
Maytag LAT7300ABX WASHER-TOP LOADING
Maytag LAT7300AGL WASHER-TOP LOADING
Maytag LAT7300AGW WASHER-TOP LOADING
Maytag LAT7300AGX WASHER-TOP LOADING
Maytag LAT7304AAE WASHER-TOP LOADING
Maytag LAT7304AAL WASHER-TOP LOADING
Maytag LAT7304AAM WASHER-TOP LOADING
Maytag LAT7304ABE WASHER-TOP LOADING
Maytag LAT7304ABL WASHER-TOP LOADING
Maytag LAT7304ABM WASHER-TOP LOADING
Admiral LAT7304AGE WASHER-TOP LOADING
Maytag LAT7304DAL WASHER-TOP LOADING
Maytag LAT7304EGE WASHER-TOP LOADING
Admiral LAT7304GGE WASHER-TOP LOADING
Maytag LAT7306AAE WASHER-TOP LOADING
Maytag LAT7314AAE WASHER-TOP LOADING
Maytag LAT7314AAL WASHER-TOP LOADING
Maytag LAT7314AAM WASHER-TOP LOADING
Maytag LAT7334AAE WASHER-TOP LOADING
Maytag LAT7334AAL WASHER-TOP LOADING
Maytag LAT7334AAM WASHER-TOP LOADING
Maytag LAT7334ABE WASHER-TOP LOADING
Maytag LAT7400AAL WASHER-TOP LOADING
Maytag LAT7400AAW WASHER-TOP LOADING
Maytag LAT7400ABL WASHER-TOP LOADING
Maytag LAT7400ABW WASHER-TOP LOADING
Maytag LAT7400ABX WASHER-TOP LOADING
Maytag LAT7480AAL WASHER-TOP LOADING
Maytag LAT7480AAW WASHER-TOP LOADING
Maytag LAT7480ABL WASHER-TOP LOADING
Maytag LAT7480ABW WASHER-TOP LOADING
Maytag LAT7500AAL WASHER-TOP LOADING
Maytag LAT7500AAW WASHER-TOP LOADING
Maytag LAT7500ABL WASHER-TOP LOADING
Maytag LAT7500ABW WASHER-TOP LOADING
Maytag LAT7500ABX WASHER-TOP LOADING
Maytag LAT7500AGL WASHER-TOP LOADING
Maytag LAT7500AGW WASHER-TOP LOADING
Maytag LAT7500AIL WASHER-TOP LOADING
Maytag LAT7500AIW WASHER-TOP LOADING
Maytag LAT7793AAL WASHER-TOP LOADING
Maytag LAT7793AAW WASHER-TOP LOADING
Maytag LAT7793ABL WASHER-TOP LOADING
Maytag LAT7793ABW WASHER-TOP LOADING
Maytag LAT7800AAL WASHER-TOP LOADING
Maytag LAT7800AAW WASHER-TOP LOADING
Maytag LAT7800ABL WASHER-TOP LOADING
Maytag LAT7800ABW WASHER-TOP LOADING
Maytag LAT7800ABX WASHER-TOP LOADING
Maytag LAT8004AAE WASHER-TOP LOADING
Maytag LAT8004AAL WASHER-TOP LOADING
Maytag LAT8004AAM WASHER-TOP LOADING
Maytag LAT8004ABE WASHER-TOP LOADING
  #2 (permalink)
Old 06-09-2011, 04:55 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG LAT2300AAE WASHER-TOP LOADING | AppliancePartsPros.com
Here is a manual for the Performa series, even though it does not list your unit with luck it will be a close match.
16023083 Maytag Performa Washers Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Have you tried different temperature settings so you can confirm that neither hot or cold work?
If both do not work, unplug the unit and one side of the water level switch (a brown wire according to the wiring diagram). Then measure across the empty contacts, it should be 0 ohms. If not replace the level switch.
FYI: This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
matag washer wont do any thing kularrow Washer Repair 1 03-18-2010 09:16 AM
Cold water problem -- Matag Washer Ruste Nale Washer Repair 3 01-27-2010 06:11 AM
matag top load washer peterkdo Dishwasher Repair 0 01-10-2010 07:23 AM
Matag washer only agitates on delicate elfretz Washer Repair 1 10-27-2009 09:09 PM
Matag washer motor problem jim b Washer Repair 0 06-09-2008 08:00 PM
