Discuss
Neptune washer not spinning
 in
Washer Repair
I have read the post by rladasamIIi concerning the washer that won't spin. I have a Neptune TL top loader.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Neptune washer not spinning
  #11 (permalink)
Old 10-26-2013, 10:51 AM
Junior Member
Skramsim is on a distinguished road
Default Re. rladsamIIi
I have read the post by rladasamIIi concerning the washer that won't spin. I have a Neptune TL top loader. Everything seems to work fine, it fills, washes, drains, starts and stops the spin cycle, and the door is locked the whole time. Only problem; it doesn't actually spin. The clothes are sopping wet even when set for max extract and even with a relatively small load of clothes.
Any suggestions? Is there a belt that could be broken or slipped?
  #12 (permalink)
Old 10-28-2013, 06:48 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Skramsim, Like all top load washers, you need to check and make sure there are no articles stuck between the tubs, especially between the spin basket and tub cover.
Being a top load Neptune washer (FAV68 or 9800) the most common issue for no spin, or "DC" or "UL" error codes is a "slipping" clutch
Part number: AP4009131
It's an easy check. Raise the top panel of the washer, program the control for a spin/drain cycle. and observe the lifter paddles. When you press the start button, the tub should start to spin, and the lifters/paddles should not rotate more than half a revolution, if they continue to rotate , no matter how little or slowly, the clutch needs to be replaced.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Neptune won't stay spinning sadist smythe Washer Repair 4 01-02-2010 06:28 AM
Neptune washer not fully spinning out Ianandevan Washer Repair 2 01-01-2010 06:42 PM
neptune washer walterwaterpolo Washer Repair 0 11-06-2009 07:29 AM
Maytag neptune washer-stop spinning superandy Washer Repair 1 06-26-2009 12:06 AM
maytag neptune frt load not spinning between cycles kimmysue Washer Repair 0 06-08-2008 08:15 AM
