Discuss
General Electric Front load washer stuck in drain cycle
 in
Washer Repair
My General Electric washing machine broke several days ago and was hoping someone could help me figure out what it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » General Electric Front load washer stuck in drain cycle
  #1 (permalink)
Old 06-07-2011, 09:34 AM
Junior Member
Jasonkmol is on a distinguished road
Default General Electric Front load washer stuck in drain cycle
Model Number: WCVH6800   Brand: GE   Age: 1 - 5 years
My General Electric washing machine broke several days ago and was hoping someone could help me figure out what it wrong and what part(s) I need to replace.
I have a WCVH6800J1WW GE washer that is 15 months old. When I try to start a washing cycle, the door locks, the machine spins in both directions several times and the machine begins running the drain pump. The drain pump runs for several minutes and the machine eventually stops. In "t02" the washer has an error code of E30 - Drain Problems
What I've already done:
1) I pulled out the drain filter and cleaned it out (wasn't much in there)
2) Gone through the service mode and tried the tests
t01 - Model ID is 04
t02 - Error Codes: E30, no other codes
t03 - Software ID: cod - 500 EE - 28 Inv - 193
t04 - LEDs: normal
t05 - Pump test: normal pumps for 60 seconds
t06 - Pressure Switch Test: pump turns on momentarily, "E" comes on display, nothing else happens
t07 - Thermistor/Heater Test: Did not try because service manual said main pressure switch must work
t10 - Tumble test: normal
t11 - Spin test: normal
t12 - Dispenser test: normal
I'm confused as to why the machine will fill with water in t12 (from both hot and cold) and drain it out appropriately, but won't function in t06 or normal wash cycles.
Any help would be greatly appreciated.
Jason
Ads By Google
Related Models
General Electric WCXR1070A0AA Washer
General Electric WCXR1070A0WW Washer
General Electric WCXR1070A1AA Washer
General Electric WCXR1070A1WW Washer
General Electric WCXR1070A2AA Washer
General Electric WCXR1070A2WW Washer
General Electric WCXR1070T2AA Washer
General Electric WCXR1070T2WW Washer
General Electric WCXR1070T3AA Washer
General Electric WCXR1070T3WW Washer
General Electric WCXR1070T4AA Washer
General Electric WCXR1070T4WW Washer
General Electric WCXR1070T5AA Washer
General Electric WCXR1070T5WW Washer
General Electric WCXR1070T8AA Washer
General Electric WCXR1070T8WW Washer
General Electric WCXR1070TAAA Washer
General Electric WCXR1070TAWW Washer
General Electric WCXR1070TBAA Washer
General Electric WCXR1070TBWW Washer
Magic Chef WCZ1050 Washer - Top Loading
Magic Chef WCZ1050AM Washer - Top Loading
Magic Chef WCZ1050W Washer - Top Loading
Thermador WD24
Thermador WD24N
Thermador WD24NS
Thermador WD24NW
Thermador WD24QB
Thermador WD24QPRS
Thermador WD24QS
Thermador WD24QW
Thermador WD24S
Thermador WD24W
Thermador WD24WC
Thermador WD27QB
Thermador WD27QPRS
Thermador WD27QS
Thermador WD27QW
Frigidaire WD300J Wwh(v1) / Disposer
Frigidaire WD301J Wwh(v2) / Disposer
Thermador WD30XB
Thermador WD30XP
Thermador WD30XS
Thermador WD30XW
Frigidaire WD350M Wwh(v3) / Disposer
Frigidaire WD500J Wwh(v3) / Disposer
Frigidaire WD550J Wwh(v1) / Disposer
Frigidaire WD551J Wwh(v2) / Disposer
Frigidaire WD750J Wwh(v3) / Disposer
Frigidaire WD850J Wwh(v1) / Disposer
White Westinghouse WDB11NRDB0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDB1 White Westinghouse/dishwasher
White Westinghouse WDB11NRDB2 White Westinghouse/dishwasher
White Westinghouse WDB11NRDQ0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS1 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS2 White Westinghouse/dishwasher
Frigidaire WDB212GBD0 Wwh(v2) / 24 " Built - in Dishwasher
Frigidaire WDB212GBW0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB212RBM0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB222RBR0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB632RBR0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB632RBS0 Wwh(v2) / 24 " Built - in Dishwasher
White Westinghouse WDB635RBQ0 White Westinghouse/dishwasher
White Westinghouse WDB635RBS0 White Westinghouse/dishwasher
Frigidaire WDB662RBR0 Wwh(v1) / 24 " Built - in Dishwasher
White Westinghouse WDB745REB0 White Westinghouse/dishwasher
White Westinghouse WDB745REB1 White Westinghouse/dishwasher
White Westinghouse WDB745REB2 White Westinghouse/dishwasher
White Westinghouse WDB745RES0 White Westinghouse/dishwasher
White Westinghouse WDB745RES1 White Westinghouse/dishwasher
White Westinghouse WDB745RES2 White Westinghouse/dishwasher
White Westinghouse WDB954MBS0 White Westinghouse/dishwasher
White Westinghouse WDB956MBC0 White Westinghouse/dishwasher
Frigidaire WDCLL0 Frg(v6) / 27 " Washer
Frigidaire WDCLW0 Frg(v5) / 27 " Washer
Frigidaire WDDH3 Frg(v3) / Top Load Washer
Frigidaire WDDL2 Frg(v13) / Top Loading Washer
Frigidaire WDDL3 Frg(v2) / Top Load Washer
Frigidaire WDDW2 Frg(v14) / Top Loading Washer
Frigidaire WDDW3 Frg(v1) / Top Load Washer
Frigidaire WDE116REW0 Wwh(v0) / Dryer
Frigidaire WDE213RHS0 Wwh(v0) / Dryer
Frigidaire WDE216RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE216RBD1 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE216RBD2 Wwh(v1) / Electric Dryer
Frigidaire WDE216RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE216RBW1 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE216RBW2 Wwh(v2) / Electric Dryer
Whirlpool WDE32202
Frigidaire WDE336RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE336RBD1 Wwh(v3) / 27 " Electric Dryer
Frigidaire WDE336RBD2 Wwh(v3) / Electric Dryer
Frigidaire WDE336RBS0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE336RBS1 Wwh(v4) / 27 " Electric Dryer
Frigidaire WDE336RBS2 Wwh(v0) / Electric Dryer
Frigidaire WDE336RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE336RBW1 Wwh(v5) / 27 " Electric Dryer
Frigidaire WDE336RBW2 Wwh(v4) / Electric Dryer
Frigidaire WDE336RED1 Wwh(v1) / Dryer
Frigidaire WDE336RES0 Wwh(v0) / Dryer
Frigidaire WDE336RES1 Wwh(v0) / Dryer
Frigidaire WDE336REW0 Wwh(v0) / Free Standing Dryer
Frigidaire WDE336REW1 Wwh(v2) / Dryer
Frigidaire WDE436RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE436RBD1 Wwh(v6) / 27 " Electric Dryer
Frigidaire WDE436RBD2 Wwh(v1) / Electric Dryer
Frigidaire WDE436RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE436RBW1 Wwh(v7) / 27 " Electric Dryer
Frigidaire WDE436RBW2 Wwh(v2) / Electric Dryer
Frigidaire WDE446JBS1 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE546RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE546RBD1 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE546RBD2 Wwh(v3) / Electric Dryer
Frigidaire WDE546RBS0 Wwh(v0) / Gas Dryer
Frigidaire WDE546RBS1 Wwh(v0) / Electric Dryer
Frigidaire WDE546RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE546RBW1 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE546RBW2 Wwh(v4) / Electric Dryer
Frigidaire WDE546RFS0 Wwh(v0) / Dryer
  #2 (permalink)
Old 06-18-2011, 07:41 PM
Junior Member
dy85p0 is on a distinguished road
Default
my washer won't drain after the last spin.
  #3 (permalink)
Old 06-18-2011, 07:43 PM
Junior Member
Default
When I wash my clothes in the front load washer, it will go to 1 and the clothes will be real wet. The drain is not working on the washing machine.
  #4 (permalink)
Old 06-18-2011, 07:46 PM
Junior Member
Default
I want to know the solution to my problem why my front load washer won't work after the spin cycle. The clothes would be real wet.
  #5 (permalink)
Old 11-15-2011, 04:34 AM
Junior Member
Stiffl05 is on a distinguished road
Default
I am currently have the same issue with my ge washer, what were you able to find and how were you able to fix the issue?
  #6 (permalink)
Old 05-07-2012, 09:53 AM
Junior Member
RichDD is on a distinguished road
Wink
t04 - LEDs: normal
Jason
I am getting the same issue. Can someone help me with this. Currently, I do have a new water valve ordered. Water is not filling the tub as fast as it used to. Also, I'd like to check the door lock mechanism, but do not know how to remove the front top control panel as well??? Any help would be appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front Load Washer Won't Drain scottbreen Washer Repair 35 01-27-2013 01:31 PM
Frigidaire Front Load Washer Won't Drain Kater Washer Repair 2 05-31-2010 06:14 AM
Washer (top load) stuck before rinse cycle lemoeb Dishwasher Repair 0 10-05-2009 06:14 AM
front load washer is not drain and spin keithzhao Washer Repair 9 12-04-2008 07:27 AM
Front Load Washer Door Stuck GlennaA Washer Repair 1 07-11-2008 06:52 PM
