The washer won't agitate on the wash mode but it will spin on the spin mode. Any suggestions?
Pull the agitator and check the block, this part here Part number: AP3964635
If that does not do it, run it with the front cover off and see if the motor is turning when the machine should be agitating. If so, the transmission may be the problem.
