Discuss
Machine rinses & drains on 1st spin cycle, but doesnt completely drain on the final!
 in
Washer Repair
Recently, my Whirlpool 8 cycle/2 speed washing machine is leaving me with a gallon or more of water in the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Machine rinses & drains on 1st spin cycle, but doesnt completely drain on the final!
  #1 (permalink)
Old 06-06-2011, 10:39 AM
Junior Member
LoveMyGolden is on a distinguished road
Question Machine rinses & drains on 1st spin cycle, but doesnt completely drain on the final!
Model Number: LLN8244AWO   Brand: Whirlpool   Age: 5 - 10 years
Recently, my Whirlpool 8 cycle/2 speed washing machine is leaving me with a gallon or more of water in the bottom, leaving my clothes soaking wet! I noticed it rinses and drains perfectly fine on the 1st rinse/spin cycle, but the final cycle is where it is not completely draining. What is causing this? What part would I need replaced as we would like to fix it ourselves.
Related Models
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
Admiral LLR1100AJQ RANGE- F/S STD GAS
Admiral LLR1100AJW RANGE- F/S STD GAS
Admiral LLR1415AJS RANGE- F/S STD GAS
Admiral LLR1415AJW RANGE- F/S STD GAS
Admiral LLR4451AJS RANGE- F/S STD GAS
Admiral LLR4451AJW RANGE- F/S STD GAS
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
Whirlpool LLR6144AN0
Whirlpool LLR6144AQ0
Whirlpool LLR6144AW0
Whirlpool LLR6144BN0 WASHER
Whirlpool LLR6144BN1 AUTOMATIC WASHER
Whirlpool LLR6144BQ0 WASHER
Whirlpool LLR6144BQ1 AUTOMATIC WASHER
Whirlpool LLR6144BW0 WASHER
Whirlpool LLR6233AN0
Whirlpool LLR6233AN1
Whirlpool LLR6233AQ0
Whirlpool LLR6233AW0
Whirlpool LLR6233AW1
Whirlpool LLR7144DQ0
Whirlpool LLR7144DW0
Whirlpool LLR7144DZ0
Whirlpool LLR8233BN0 AUTOMATIC WASHER
Whirlpool LLR8233BN1 AUTOMATIC WASHER
Whirlpool LLR8233BQ0 AUTOMATIC WASHER
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
Whirlpool LLT8233DQ0
Whirlpool LLT8233DZ0
Whirlpool LLT8244AN0
Whirlpool LLT8244AQ0
Whirlpool LLT8244AW0
Whirlpool LLT8244AZ0
Whirlpool LLT8244BQ0
Whirlpool LLT8244BQ1
Whirlpool LLT8244BZ0
Whirlpool LLT8244BZ1
Whirlpool LLT8244DQ0
Whirlpool LLT8244DZ0
Whirlpool LLV6144AG0
Whirlpool LLV6144AN0
Whirlpool LLV6144AW0
Whirlpool LLV6144BN0
Whirlpool LLV6144BW0
Whirlpool LLV7233AW0
Whirlpool LLV7244AG0
Whirlpool LLV7244AN0
Whirlpool LLV7244AW0
Whirlpool LLV8233BN0
Whirlpool LLV8233BQ0
Whirlpool LLV8233BW0
Whirlpool LLV8245AG0
Whirlpool LLV8245AN0
Whirlpool LLV8245AW0
Whirlpool LLV8245BN0
Whirlpool LLV8245BW0
Whirlpool LLV8245DQ0
Whirlpool LLV8245DZ0
 LM-1830C2L Air Conditioner
 LM-2430C2L Air Conditioner
 LM-2430H2L Air Conditioner
 LM360CE Air Conditioner
Whirlpool LMA1053LQ0
Whirlpool LMA1053LT0
 LMA1150SV Microwave Oven
 LMA1560SB Microwave Oven
 LMA2111ST Microwave Oven
 LMAN090CNS.ANCAEUS Air Conditioner
 LMAN090HNS Air Conditioner
 LMAN120CNS Air Conditioner
 LMAN120HNS Air Conditioner
 LMAN121CNM Air Conditioner
 LMAN121HNM Air Conditioner
 LMH1017CVST Microwave Oven
 LMN090CE.AWHAEUS Air Conditioner
 LMN090HE Air Conditioner
 LMN120EC.AWHAEUS Air Conditioner
 LMN120HE Air Conditioner
 LMN2430H2L Air Conditioner
  #2 (permalink)
Old 06-08-2011, 07:31 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Since it is working correctly through one cycle, that suggests that the problem is not mechanical but electrical. I would try replacing the timer, it is a relatively easy job that you should be able to do just fine.
__________________
  #3 (permalink)
Old 06-08-2011, 12:00 PM
Junior Member
Angry
Quote:
Thanks Sidfink43...I wasn't sure if it was that or a pump. (Also, don't know if I clarified this... it does actually spin on the last spin cycle, just that the water isn't drained out.) Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
outer tub doesnt spin or drain at last cycle goodtymes Washer Repair 1 09-25-2010 02:21 AM
Final Spin Drains halfway Rick33931 Washer Repair 1 08-31-2010 09:47 AM
WhirlPool doesnt completely drain chris18j2002 Dishwasher Repair 0 07-02-2010 06:06 AM
doesnt spin on final spin cycle tonito Washer Repair 1 09-13-2009 10:37 AM
washer doesnt spin water out in final rinse pdmayhugh52 Washer Repair 0 07-09-2008 04:32 PM
