| » whirlpool duet f70/f71 |
Model Number: wfw9500tw01 Brand: Whirlpool Age: 1 - 5 years
try to wash,nothing ,after got the f70 code,unplug it,plug back on ,nothing,no lights,only 3 beeps,and after 1 hour the f71 code please help
Quote:
The F70 and F71 codes indicate two things, either a bad CCU(central control unit) or UIC(user interface control) for one reason or another they are not communicating. Part number: AP4343491 Part number: AP4538151 Here's a quick test procedure to help determine which part you may need: First unplug the power cord, and remove the top of the washer( 3 screws across the back and slide the top back, until the hidden clips release the top). Possible Causes/Procedure Check for continuity of the User Interface harness. Check wire harness connections to the User Interface and the Central Control Unit. If the drum is not rotating, unplug the MCU from the CCU (the MI3 or M13 connector). If the code disappears, replace the MCU. If the code does not disappear, replace the CCU. Replace User Interface if drum is rotating. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Whirlpool Duet f71 | 91boz | Washer Repair | 2 | 11-08-2009 04:05 PM |
| whirlpool duet | akosley | Washer Repair | 1 | 08-23-2009 06:50 AM |
| Whirlpool Duet | TMRAY | Washer Repair | 4 | 05-13-2009 12:32 PM |
| whirlpool duet | LLIN0321 | Dishwasher Repair | 5 | 07-24-2008 08:29 PM |
