Discuss
Whirlpool Direct Drive - reasons for drive coupling failing
 in
Washer Repair
I have a Whirlpool washer that broke the plastic drive connector on the motor. I replaced it and on the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Direct Drive - reasons for drive coupling failing
  #1 (permalink)
Old 11-12-2007, 05:40 AM
FriarTuck FriarTuck is offline
Junior Member
FriarTuck is on a distinguished road
Default Whirlpool Direct Drive - reasons for drive coupling failing
Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool washer that broke the plastic drive connector on the motor. I replaced it and on the first load the replacement connector rounded off on the motor shaft during the spin cycle.
With the motor out of the washer, I can easily turn the transmission shaft counter-clockwise by hand and make the agitator work. However, when I try to turn the shaft clockwise I encounter strong resistance. I'm guessing that if that resistance is not normal it is the cause of the connectors failing. I would appreciate suggestions as to what might be causing the connector to fail.
  #2 (permalink)
Old 11-12-2007, 02:34 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
Hi FriarTuck
There is a resistance because of breaks which should be released for the spin cycle by the clutch. It needs much more force.
The reasons why the new part broke could be misalignment during the installation or a crack in the plastic part.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool belt-drive won't spin when it's supposed to Lmarks Washer Repair 13 10-03-2007 05:41 PM
Direct Drive Washer JNOLES Washer Repair 1 09-19-2007 05:24 PM
Drive Belt Dimensions rcarter Washer Repair 1 09-19-2007 05:12 PM
Drive block keeps slipping. vanmaarth Washer Repair 3 08-15-2007 09:00 PM
never replaced a drive belt before stonebuster Washer Repair 0 08-10-2007 05:23 PM
