Washer rocks out of control in spin cycle
Washer Repair
washer spins out of round in the spin cycle as if clothes are unbalanced even without clothes in the tub.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer rocks out of control in spin cycle
  #1 (permalink)
Old 06-03-2011, 07:15 AM
JDA JDA is offline
Junior Member
JDA is on a distinguished road
Default Washer rocks out of control in spin cycle
Model Number: KAWE577BWH1   Brand: Kitchen Aid   Age: 5 - 10 years
washer spins out of round in the spin cycle as if clothes are unbalanced even without clothes in the tub. What parts do I need to correct this?
Related Models
Whirlpool KAWE578BAL0
Whirlpool KAWE578BAL1
Whirlpool KAWE650VAL0
Whirlpool KAWE650VWH0
Whirlpool KAWE660WAL0
Whirlpool KAWE660WAL1
Whirlpool KAWE660WAL2
Whirlpool KAWE660WAL3
Whirlpool KAWE660WWH0
Whirlpool KAWE660WWH1
Whirlpool KAWE660WWH2
Whirlpool KAWE660WWH3
Whirlpool KAWE667BWH0
Whirlpool KAWE668BAL0
Whirlpool KAWE668BAL1
Whirlpool KAWE670BAL0
Whirlpool KAWE670BWH0
Whirlpool KAWE670BWH1
Whirlpool KAWE677BWH0
Whirlpool KAWE677BWH1
Whirlpool KAWE678BAL0
Whirlpool KAWE678BAL1
Whirlpool KAWE679BBL0
Whirlpool KAWE679BBL1
Whirlpool KAWE700TWH0
Whirlpool KAWE742BAL0
Whirlpool KAWE742BWH0
Whirlpool KAWE742VAL0
Whirlpool KAWE742VWH0
Whirlpool KAWE742WAL0
Whirlpool KAWE742WAL1
Whirlpool KAWE742WAL2
Whirlpool KAWE742WAL3
Whirlpool KAWE742WWH0
Whirlpool KAWE742WWH1
Whirlpool KAWE742WWH2
Whirlpool KAWE742WWH3
Whirlpool KAWE750VAL0
Whirlpool KAWE750VWH0
Whirlpool KAWE755VAL0
Whirlpool KAWE755VWH0
Whirlpool KAWE760WAL0
Whirlpool KAWE760WAL1
Whirlpool KAWE760WWH0
Whirlpool KAWE760WWH1
Whirlpool KAWE760WWH2
Whirlpool KAWE760WWH3
Whirlpool KAWE764WAL0
Whirlpool KAWE764WAL1
Whirlpool KAWE764WAL2
Whirlpool KAWE764WWH0
Whirlpool KAWE764WWH1
Whirlpool KAWE764WWH2
Whirlpool KAWE767BWH0
Whirlpool KAWE767WAL0
Whirlpool KAWE767WWH0
Whirlpool KAWE768BAL0
Whirlpool KAWE768BAL1
Whirlpool KAWE768BWH0
Whirlpool KAWE770BAL0
Whirlpool KAWE770BWH0
Whirlpool KAWE770BWH1
Whirlpool KAWE777BWH0
Whirlpool KAWE777BWH1
Whirlpool KAWE778BAL0
Whirlpool KAWE778BAL1
Whirlpool KAWE800SWH1
Whirlpool KAWE800TWH0
Whirlpool KAWE842WAL0
Whirlpool KAWE842WAL1
Whirlpool KAWE842WAL2
Whirlpool KAWE842WWH0
Whirlpool KAWE842WWH1
Whirlpool KAWE842WWH2
Whirlpool KAWE850VAL0
Whirlpool KAWE850VAL1
Whirlpool KAWE850VWH0
Whirlpool KAWE850VWH1
Whirlpool KAWE860WAL0
Whirlpool KAWE860WAL1
Whirlpool KAWE860WAL2
Whirlpool KAWE860WAL3
Whirlpool KAWE860WWH0
Whirlpool KAWE860WWH1
Whirlpool KAWE860WWH2
Whirlpool KAWE860WWH3
Whirlpool KAWE870BAL0
Whirlpool KAWE870BWH0
Whirlpool KAWE870BWH1
Whirlpool KAWE877BWH1
Whirlpool KAWE878BAL1
Whirlpool KAWE900SWH1
Whirlpool KAWE900SWH2
Whirlpool KAWE900TWH0
Whirlpool KAWE900TWH1
Whirlpool KAWE950VAL0
Whirlpool KAWE950VWH0
Whirlpool KAWE960WAL0
Whirlpool KAWE960WAL1
Whirlpool KAWE960WWH0
Whirlpool KAWE960WWH1
Whirlpool KAWE977BWH0
Whirlpool KAWE977DWH0
Whirlpool KAWL400WAL0
Whirlpool KAWL400WAL1
Whirlpool KAWL400WWH0
Whirlpool KAWL400WWH1
Whirlpool KAWL410BAL0
Whirlpool KAWL410BWH0
Whirlpool KAWL410BWH1
Whirlpool KAWL500WAL0
Whirlpool KAWL500WWH0
Whirlpool KAWL510BAL0
Whirlpool KAWL510BWH0
Whirlpool KAWL517BWH0
  #2 (permalink)
Old 06-03-2011, 01:11 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Did this happen all of a sudden, or progressively worse as time past ?
First check and make sure the washer is level, the rear self adjusting,levelling rear feet are locked in place( raise the rear of the washer a few inches of the floor and let it fall back down).
You'll need to remove the washer cabinet, and check the suspension springs and slide plates for excessive wear and tear, or loose/missing springs,etc.
You didn't mention if there any strange noises,
Here's some help for you to access the inside components and suspension parts :
1. Remove
the two Phillips-head screws securing the front corners of the console to the washer top( these 2 screws could also be located on the back side of the control panel end caps, under the decorator trim strips on the front of the control panel) panel.
2. Tip the console back on the hinges that secure the top of the console to the washer back.
Components inside the washer cabinet can be accessed by completely removing the outer cabinet as one unit.
1. Remove the console mounting screws and tilt the console into the service position.
2. Unplug the lid switch harness connector from the receptacle in the washer top.
3. Remove the cabinet mounting clips by placing the flat blade of a screwdriver in the clip.
4. Remove the cabinet by tilting it forward and pulling it away from the washer.
5. The rear panel can be tilted back for additional access to components at rear.
Good Luck,
Thanks for allowing AppliancePartsPros.com to assist you,
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer out of control during spin cycle tombecca Washer Repair 0 01-22-2011 08:37 AM
GE Washer Rocks when in spin cycle Shaughn essys Washer Repair 1 11-01-2010 09:08 PM
Washer rocks house when spinning dianascales52 Washer Repair 1 12-13-2009 08:22 AM
Frigidaire washer tub just rocks back an forth jfwsmith Washer Repair 1 11-06-2009 05:51 PM
washer rocks/unbalance - leveling mechanism failed? alt2mn Washer Repair 2 11-17-2008 08:01 AM
