How to test motor vs. lid switch
Model Number: MAV6458AWW Brand: Maytag Age: 5 - 10 years
In our last load of laundry, we found that the machine had stopped and there was an electrical smell in the air. No burning rubber, no metallic (clutch) smells. Now the washer will fill with water, but then nothing happens. No matter what I turn the dial to, it will not respond. It won't even drain the water that's in it.
I cannot find a service manual for this model. How can I test if we overloaded it and the motor has blown (a definite possibility considering the load was all heavy towels)...or if the lid switch has gone bad (seems very likely considering the symptoms).
When I look at the wiring diagram under the "lid switch connector and operation", it specifically says "link continuity cannot be measured with ohmmeter". So how do I test it?
Thanks!
Ads By Google
Related ModelsMaytag MAV6458AWW Washer, Atlantis Maytag MAV6548AWQ Washer, Atlantis Maytag MAV6548AWW Washer, Atlantis Maytag MAV6601AWQ Washer, Atlantis Maytag MAV6601AWW Washer, Atlantis Maytag MAV6650AWW Washer, Atlantis Maytag MAV7000AWQ Washer, Atlantis Maytag MAV7000AWW Washer, Atlantis Maytag MAV7057AWQ Washer, Atlantis Maytag MAV7057AWW Washer, Atlantis Maytag MAV7200AWQ Washer, Atlantis Maytag MAV7200AWW Washer, Atlantis Maytag MAV7257AWQ Washer, Atlantis Maytag MAV7257AWW Washer, Atlantis Maytag MAV7258AWQ Washer, Atlantis Maytag MAV7258AWW Washer, Atlantis Maytag MAV7260AWW Washer, Atlantis Maytag MAV7260BWW Washer, Atlantis Maytag MAV7357AWQ Washer, Atlantis Maytag MAV7357AWW Washer, Atlantis Maytag MAV7358AWQ Washer, Atlantis Maytag MAV7358AWW Washer, Atlantis Maytag MAV7450AWQ Washer, Atlantis Maytag MAV7450AWW Washer, Atlantis Maytag MAV7501EWW Washer, Atlantis Maytag MAV7504EWW Washer, Atlantis Maytag MAV7550AWQ Washer, Atlantis Maytag MAV7550AWW Washer, Atlantis Maytag MAV7551AWQ Washer, Atlantis Maytag MAV7551AWW Washer, Atlantis Maytag MAV7557EWQ Washer, Atlantis Maytag MAV7557EWW Washer, Atlantis Maytag MAV7580EWQ Washer, Atlantis Maytag MAV7580EWW Washer, Atlantis International MAV7600ACQ Washer - Top Loading International MAV7600AGW Washer - Top Loading Maytag MAV7600AWQ Washer, Atlantis Maytag MAV7600AWW Washer, Atlantis International MAV7600BGW Washer - Top Loading International MAV7600CGW Washer - Top Loading Maytag MAV7650AWQ Washer, Atlantis Maytag MAV7650AWW Washer, Atlantis Maytag MAV7657EWQ Washer, Atlantis Maytag MAV7657EWW Washer, Atlantis Maytag MAV7700AWQ Washer, Atlantis Maytag MAV7700AWW Washer, Atlantis International MAV7750AGW Washer - Top Loading International MAV7750BGW Washer - Top Loading International MAV7750CGW Washer - Top Loading Maytag MAV7757AWQ Washer, Atlantis Maytag MAV7757AWW Washer, Atlantis Maytag MAV8000AWQ Washer, Atlantis Maytag MAV8000AWW Washer, Atlantis Maytag MAV8057AWQ Washer, Atlantis Maytag MAV8057AWW Washer, Atlantis Maytag MAV8260AWQ Washer, Atlantis Maytag MAV8260AWW Washer, Atlantis Maytag MAV8500AWA Washer, Atlantis Maytag MAV8500AWQ Washer, Atlantis Maytag MAV8500AWW Washer, Atlantis Maytag MAV8551AWQ Washer, Atlantis Maytag MAV8551AWW Washer, Atlantis Maytag MAV8557AWQ Washer, Atlantis Maytag MAV8557AWW Washer, Atlantis Maytag MAV8600AWQ Washer, Atlantis Maytag MAV8600AWW Washer, Atlantis Maytag MAV8601AWQ Washer, Atlantis Maytag MAV8601AWW Washer, Atlantis Maytag MAV8757AWQ Washer, Atlantis Maytag MAV8757AWW Washer, Atlantis Maytag MAV9501EWQ Washer, Atlantis Maytag MAV9501EWW Washer, Atlantis Maytag MAV9504EWQ Washer, Atlantis Maytag MAV9504EWW Washer, Atlantis Maytag MAV9557EWQ Washer, Atlantis Maytag MAV9557EWW Washer, Atlantis Maytag MAV9600EWQ Washer, Atlantis Maytag MAV9600EWW Washer, Atlantis Maytag MAV9657EWQ Washer, Atlantis Maytag MAV9657EWW Washer, Atlantis Maytag MAV9750AGW Washer, Atlantis Maytag MAV9750AWQ Washer, Atlantis Maytag MAV9750AWW Washer, Atlantis Maytag MAVT236AWW Washer - Top Loading Maytag MAVT346AWW Washer - Top Loading Maytag MAVT446AWW Washer - Top Loading Maytag MAVT546EWW Washer - Top Loading Maytag MAVT634AWW Washer, Atlantis Maytag MAVT734EWW Washer, Atlantis Maytag MAVT754EWW Washer, Atlantis Maytag MAVT834AWQ Washer, Atlantis Maytag MAVT834AWW Washer, Atlantis Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot International MB1927PEHB Ref - Maytag Int'l Bot Mount International MB1927PEHW Ref - Maytag Int'l Bot Mount International MB2216PUAW Ref - Bottom Mounts International MB2227PEHB Ref - Maytag Int'l Bot Mount International MB2227PEHW Ref - Maytag Int'l Bot Mount Thermador MB245 General Electric MB536BB1 Electric range Whirlpool MB7120XYB0 Whirlpool MB7120XYB1 General Electric MB757WB1 Electric range Maytag MBB1952GRQ Ref - Bottom Mounts Maytag MBB1952GRW Ref - Bottom Mounts Maytag MBB1952HEB Ref - Bottom Mounts Maytag MBB1952HEQ Ref - Bottom Mounts Maytag MBB1952HEW Ref - Bottom Mounts Maytag MBB1954GEB Ref - Bottom Mounts Maytag MBB1954GEQ Ref - Bottom Mounts Maytag MBB1954GES Ref - Bottom Mounts Maytag MBB1954GEW Ref - Bottom Mounts Maytag MBB1954HEW Ref - Bottom Mounts Maytag MBB1956GEB Ref - Bottom Mounts Maytag MBB1956GEQ Ref - Bottom Mounts Maytag MBB1956GES Ref - Bottom Mounts Maytag MBB1956GEW Refrigerator Maytag MBB1956HEB Ref - Bottom Mounts Maytag MBB1956HEQ Ref - Bottom Mounts Maytag MBB1956HES Ref - Bottom Mounts
Reason: more information
