Discuss
GE Washing Machine
 in
Washer Repair
My GE washing machine goes through all the cycles without a problem. However, when it reaches the spin cycles it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washing Machine
  #1 (permalink)
Old 11-11-2007, 04:30 PM
Billk Billk is offline
Junior Member
Billk is on a distinguished road
Default GE Washing Machine
Model Number: WPSR3100W2WW   Brand: GE   Age: 5 - 10 years
My GE washing machine goes through all the cycles without a problem. However, when it reaches the spin cycles it does not drain
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-11-2007, 05:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Billk
Remove the front panel and check the drain pump.
If it runs but does not drain, most likely there are a foreign objects inside the drain hoses or the pump impeller.
It should be 120V coming to the pump when the timer is set for spin (the lid should be closed).
If there is no proper power coming to the pump and the washer spins, then the problem could be a bad wires or a bad timer.
If the washer does not drain and spin, then it could be a bad lid switch, a bad wires or a bad timer.
If there is 120V coming to the pump but the pump does not run, then the pump itself is bad.
- The part number for the pump AP3193205
- The part number for the timer AP2045964
- The part number for the lid switch AP2620150
- Here are the break down diagrams for the GE washer Model WPSR3100W2WW
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing machine Novice Washer Repair 2 10-08-2007 12:22 PM
Washing Machine Gtaeza Dishwasher Repair 0 09-27-2007 09:19 AM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 03:42 AM
Washing Machine jherriff Washer Repair 1 09-10-2007 12:03 PM
GE washing machine paul Washer Repair 2 07-19-2007 08:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
