Discuss
washer won't fill up and makes a gurggling noise
 in
Washer Repair
Hello.I just joined and any help would be greatly apprieciated.My sisters washer won't fill up and makes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't fill up and makes a gurggling noise
  #1 (permalink)
Old 02-18-2009, 12:26 PM
batterinram batterinram is offline
Junior Member
batterinram is on a distinguished road
Default washer won't fill up and makes a gurggling noise
Model Number: vbxr1060t5wb   Brand: Hotpoint   Age: More than 10 years
Hello.I just joined and any help would be greatly apprieciated.My sisters washer won't fill up and makes a gurggling noise.I checked the water lines and they are unobstructed.I changed out the water inlet valve and still no water.I'm hoping it's something simple(aren't we all)since I obviously have little working knowledge.Thanks in advance.
Related Models
General Electric VBXR1060T5WB Washer
General Electric VBXR1060T8AB Washer
General Electric VBXR1060T8WB Washer
General Electric VBXR1060TAAB Washer
General Electric VBXR1060TAWB Washer
General Electric VBXR1060V0AA Washer
General Electric VBXR1060V0WW Washer
General Electric VBXR1060V1AA Washer
General Electric VBXR1060V1WW Washer
General Electric VBXR1070W0AA Washer
General Electric VBXR1070W0WW Washer
General Electric VBXR1070W1AA Washer
General Electric VBXR1070W1WW Washer
General Electric VBXR1070W2AA Washer
General Electric VBXR1070W2WW Washer
General Electric VBXR1090B0CC Washer
General Electric VBXR1090B0WW Washer
General Electric VBXR1090B2CC Washer
General Electric VBXR1090B2WW Washer
General Electric VBXR1090B3CC Washer
General Electric VBXR1090B3WW Washer
General Electric VBXR1090B4CC Washer
General Electric VBXR1090B4WW Washer
General Electric VBXR1090D0CC Washer
General Electric VBXR1090D0WW Washer
General Electric VBXR1090D1WW Washer
General Electric VBXR1090D2CC Washer
General Electric VBXR1090D2WW Washer
General Electric VBXR1090D3WW Washer
General Electric VBXR1090D4WW Washer
General Electric VBXR1090D5CC Washer
General Electric VBXR1090D5WW Washer
General Electric VBXR1090D6WW Washer
General Electric VBXR1090D7WW Washer
General Electric VBXR1090D8CC Washer
General Electric VBXR1090D8WW Washer
General Electric VBXR1090D9WW Washer
General Electric VBXR1090DACC Washer
General Electric VBXR1090DAWW Washer
General Electric VBXR1090DBCC Washer
General Electric VBXR1090DBWW Washer
General Electric VBXR1090DDCC Washer
General Electric VBXR1090DDWW Washer
General Electric VBXR2070T2AB Washer
General Electric VBXR2070T2WB Washer
General Electric VBXR2070T3AB Washer
General Electric VBXR2070T3WB Washer
General Electric VBXR2070T5AB Washer
General Electric VBXR2070T5WB Washer
General Electric VBXR2070T6AB Washer
General Electric VBXR2070T6WB Washer
General Electric VBXR2070T8AB Washer
General Electric VBXR2070T8WB Washer
General Electric VBXR2070TAAB Washer
General Electric VBXR2070TAWB Washer
General Electric VBXR2070V0AA Washer
General Electric VBXR2070V0WW Washer
General Electric VBXR2070V1AA Washer
General Electric VBXR2070V1WW Washer
Thermador VC-500
Gaggenau VC112-602
Gaggenau VC113-602
Gaggenau VC114-602
Gaggenau VC116-602
Gaggenau VC230-612
Gaggenau VC343-602
Gaggenau VC345-602
Gaggenau VC355-602
Thermador VCH-2
Thermador VCH-3
Thermador VCH-6
Thermador VCH-6A
Thermador VCH-7
Thermador VCH-7A
Thermador VCH-8
Thermador VCH-9
Amana VCH3 Ele Cartridge
Thermador VCH36
Amana VCH4 Ele Cartridge
Thermador VCH54
Thermador VCK-1
Thermador VCK-1A
Thermador VCK-300
Bosch VD030-000
Bosch VD030-010
Bosch VD030-099
Bosch VD040-000
Bosch VD040-010
Bosch VD040-099
Bosch VD050-010
Gaggenau VE112-612
Frigidaire VE21AW5 Tap(v1) / Electric Range
Amana VE3013 Washer - Top Loading
Frigidaire VE30AW5 Tap(v1) / Electric Range
Frigidaire VE30BW4 Tap(v1) / Electric Range
Frigidaire VE30CW4 Tap(v1) / Electric Range
Gaggenau VE313-613
Amana VE5013 Washer - Top Loading
Amana VEND-10.000 Commercial Microwaves
Amana VEND-10.A Commercial Microwaves
Amana VEND-10.B Commercial Microwaves
Amana VEND-10.C Commercial Microwaves
Amana VEND-10.F Commercial Microwaves
Amana VEND-10.G Commercial Microwaves
Amana VEND-10.H Commercial Microwaves
Amana VEND-10.J Commercial Microwaves
Amana VEND-7.003 Commercial Microwaves
Amana VEND-7.004 Commercial Microwaves
Amana VEND-7.005 Commercial Microwaves
Amana VEND-7.A Commercial Microwaves
Amana VEND-7.B Commercial Microwaves
Amana VEND-7D.001 Commercial Microwaves
Amana VEND-7D.A Commercial Microwaves
Amana VEND10 Commercial Microwaves
Amana VEND11 Commercial Microwaves
Amana VEND11B Commercial Microwaves
Hoover VER1360AGH Range - F/s Std Ele
Gaggenau VF112-610
Gaggenau VF230-610
  #2 (permalink)
Old 02-19-2009, 08:16 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Model VBXR1060T5WB
It sounds like the drain pump is running.
Do you have the wiring diagram?
They like to put it in the control console.
I will not be able to find one one the internet, GE likes to keep them a secret from the public and Hotpoint is a GE machine.
If you advance the timer will it do anything else re: Agitate or spin?
Here is a good site to give you some basic troubleshooting help
http://www.applianceaid.com/washers.html
Could be that the timer contacts that run the pump are welded together.
__________________
  #3 (permalink)
Old 02-19-2009, 09:41 AM
Junior Member
Default
thanks for the response.I do have the wiring diagram.The washer does spin and agitate.if it is the contacts what should I do next?
Thanks again.
  #4 (permalink)
Old 02-19-2009, 03:03 PM
Senior Expert
APP Volunteer
Default
I would try to figure it out from the wiring diagram.
Perhaps open up the control console and check the wires.
You have 2 problems.
1. If the gurgling is the pump it is somehow getting power when it shouldn't
2. For some reason the fill valve is not running at the start of a cycle.
This is usually controlled by a set of timer contacts and the fill pressure switch. One side of the pressure switch is closed giving power to the fill valve. When the pressure in the tube from the water rises to the set point the switch trips. This removes power to the fill valve and now gives power to the timer so it starts agitating.
Here is a link which should help you narrow it down
Perhaps someone who has seen this exact problem will jump in and have an answer.
__________________
  #5 (permalink)
Old 02-19-2009, 04:15 PM
Junior Member
Default
thanks for your replies.I guess I'll check the pressure switch next.
Thanks again
  #6 (permalink)
Old 02-20-2009, 05:41 AM
Senior Expert
APP Volunteer
Default
I would take a meter and check the pump contacts at the timer.
Unplug the unit.
Unplug the timer's connector
Measure across the contacts for resistance while manually turning it
They should open and close depending where in the cycle you are.
If they stay closed then at the very least you need a new timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer makes grinding noise. wont spin montanaJohn Washer Repair 5 11-02-2009 02:37 AM
Washer makes load noise during spin driley Washer Repair 7 11-10-2008 12:53 PM
washer won't spin, makes noise brokenshoe Washer Repair 3 07-01-2008 09:05 PM
washer makes noise in spin cycle Jamesandloretta Washer Repair 2 03-24-2008 05:25 PM
Washer makes noise and does not spin rjr Washer Repair 1 12-30-2007 03:08 AM
