Everything seems to work perfectly, except during the period where it should spin, it doesnot, it fills up with water, but doesnot agitates, then it drains normally as it always does, but no agitate!.
What should I do?
Does this happen in all the cycles?
Originally Posted by: magician59 Does this happen in all the cycles? No, it doesnot, only during the cycle where it should spin/agitate Theres no problems with the other cycles.
It sounds like a bad timer.
