Discuss
No spin cycle
 in
Washer Repair
I have a Maytag top load washer model # PAV1000AWW. The tub fills with water but it will not spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No spin cycle
  #1 (permalink)
Old 06-02-2011, 04:37 AM
Junior Member
Bonnie1577 is on a distinguished road
Default No spin cycle
Brand: Maytag   Age: More than 10 years
I have a Maytag top load washer model # PAV1000AWW. The tub fills with water but it will not spin or drain. I can hear a faint buzzing sound but nothing else. I was told that the problem might be the timer so I replaced it but that did not correct the problem. Any suggestions?
Ads By Google
  #2 (permalink)
Old 06-03-2011, 05:36 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Take off the front panel and check for something caught inbetween the tub and basket. Then see if the pulley will turn in the spin direction. I am guessing that it will not, which means that the problem is likely with the brakes haning up or the transmission.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer - wont stop last spin cycle + how long spin cycle suppose to last? tc38 Washer Repair 3 04-29-2011 07:49 PM
Roper washer spins on rinse cycle but not on spin cycle Swica Washer Repair 4 03-07-2011 05:23 PM
loud noise on spin cycle,the faster the spin gets the louder the winnig gets Edward Loeb Washer Repair 3 02-02-2011 07:30 AM
Washer will not go through rinse or spin cycle on regular cycle dhilde7165 Washer Repair 0 02-14-2009 04:10 PM
Maytag wash won't spin on regular cycle but will on gentle cycle BlazingSun Washer Repair 0 01-07-2009 08:41 PM
