Discuss
error code 01
 in
Washer Repair
i already check for the hot water valve and after the test i concluded that i need to replace it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » error code 01
  #1 (permalink)
Old 11-11-2007, 12:33 PM
platini platini is offline
Junior Member
platini is on a distinguished road
Default error code 01
Model Number: wfk2401   Brand: Bosch   Age: 5 - 10 years
i already check for the hot water valve and after the test i concluded that i need to replace it never stops running. now when i do a wash on cold only(since i am still waiting for the part) it starts fine but in the middle it stops and come the code 01 door locked. it seems that the cold water is not comming fast enough, but at the begining of a wash it works i can hear the warter comming on full force but after the first spin it just trikle. do i also need to order a cold water dual vave?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-12-2007, 01:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi platini
The first thing I would do before ordering any parts is perform all tests recommended by the manufacturer as described in the attached manual.
- Here are the break down diagrams for the Bosch washer Model WFK2401
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-12-2007, 10:31 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi platini
Good luck.
hi gene
thank you for your response, i would have never thought that a forum for washing machine existed, i am a active member of a an other forum for my motorcycle and it is the same things we do help each other very quickly with any type of problem we can have. i ran all the test and the only thing i noticed is when i did the test #3 for each valve, the one when we push prewash comes super slow it just trickle down on test # 2 all went well. after that i tried a regular wash on cycle 2 it started well but in the middle i got the error 01 no water filling i guess the dual valve need to be replace am i wright?at the begining of the wash the water fills quickly with a strong flow from the right of the dual valve but in the middle of the wash after the first spin the left side of the dual valve come in super slow and it is when i get the 01 error.
  #4 (permalink)
Old 11-26-2007, 06:18 AM
choofly choofly is offline
Junior Member
choofly is on a distinguished road
Default
that's exactly what's happening to mine; i also had the same result from test#3. so i'm going to replace the dual valve. i hope it works. will post back in a week or two, when i get the part and find someone to help me move the dryer.
  #5 (permalink)
Old 11-29-2007, 10:01 AM
pam schmidt pam schmidt is offline
Junior Member
pam schmidt is on a distinguished road
Default Bosch washer nexxt
the washer has filled up with water and will not drain. the E04 error code flashes.... ( there is not an authorized repair person in our rural areas...)
  #6 (permalink)
Old 11-29-2007, 12:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
Post it as a new thread, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 error code mich26 Microwave Repair 3 01-23-2008 07:28 PM
Kitchen Aid Code Error F7 E0 Sailn Oven Repair (including Ranges and Cooktops) 0 09-30-2007 08:25 AM
F 1 Error Code Frogburk Oven Repair (including Ranges and Cooktops) 1 08-29-2007 03:10 PM
e-10 error code hoogabooga Washer Repair 0 08-28-2007 03:57 PM
F2 - Error Code Wilson Oven Repair (including Ranges and Cooktops) 3 08-23-2007 10:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
