lg washer had le code unplugged to erase code turned back on making squicking noise when on tried to turn on and just drain can not get washer to do that on spin it show thirty minutes
Your post is a little bit garbled, but I can say that the LE error codes on these LG's is the washing machine version of diagnostic purgatory. The code means the control board does not know if the motor is turning.
This can be the motor, wiring, hall sensor and several other things. I wish I could tell you more but even LG service techs have trouble with this one and usually end up just replacing parts until it works.
