My washer won't drain the final rinse in the knits/gentle cycle or the permanent press cycle - which are the two cycles I use the most. However, it will run through completely in the regular cycle.
What do you think the problem is and is it worth fixing or just buying a new one? With all the negative reviews on new "low-end" washers breaking down, don't know if I should fix the old or buy new.
Thanks.
Originally Posted by: magician59 Thank you!
