Discuss
Pump
 in
Washer Repair
OK...Have Disassembled Washer to Inspect cause(s) of Water Leaking during Fill & Spin Cycles. Have Removed "PumP" which is attached
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Pump
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-30-2011, 01:53 PM
Junior Member
loco47 is on a distinguished road
Unhappy Pump
Model Number: LSQ9200PQ4   Brand: Whirlpool   Age: 5 - 10 years
Have Removed "PumP" which is attached to Two Hoses. This was leaking upon Inspection & before removing Hoses...however, I cannot see Any problems with the Pump Casing?
Also, upon removing Cabinet...there was Below the Pump described above, a Plastic Sleeve, if you will, that I've No Idea how it may append to the Pump??? I'm sure it does!
Part#'s are: Pump 8559389 ASS'Y; 3352293 WPI
Sleeve: 8539874
Once again...thank you kindly!
loco47
Related Models
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
  #2 (permalink)
Old 05-30-2011, 01:56 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
If the pump was leaking, there is no other repair than to replace it.
Part number: AP2907492
  #3 (permalink)
Old 05-30-2011, 02:22 PM
Junior Member
Default
YUP...Mr Magician59! That's the badboy...But, can you please expound regarding the "Sleeve" I had mentioned? It was lying upon the floor Directly Below the Pump...I can only assume (mistake!) that the Sleeve belongs Somehow Affixed to the Pump Body???
Thanks again,
loco47
  #4 (permalink)
Old 05-30-2011, 03:38 PM
Junior Member
Default
Ah...I was correct saying It's a Mistake to Assume! The Sleeve previously described is, in fact, a SudsShield that goes on back of machine; on Rt side...Somehow!
Regards,
loco47
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pump replacement/ Wash pump Buzzing mikehotelfoxtrot Dishwasher Repair 0 03-17-2011 11:28 AM
dishwasher wash pump will not pump streetguy Dishwasher Repair 1 01-19-2011 08:13 AM
Bosch washer pump issue (already replaced pump!) wdt Washer Repair 0 12-02-2008 06:26 AM
will this pump also pump the drain water out Paul Radovsky Dishwasher Repair 5 07-20-2008 01:41 PM
sock stuck in water pump... do i need a new pump? volcompunker82 Washer Repair 0 03-08-2008 07:20 PM
