Discuss
No Agitation, Grinding noise
 in
Washer Repair
Washer will not agitate or spin. Drains fine. Has a grinding noise from motor or transmission. I think this is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No Agitation, Grinding noise
  #1 (permalink)
Old 02-15-2009, 08:48 AM
Junior Member
harleyt is on a distinguished road
Question No Agitation, Grinding noise
Model Number: LSQ9610JQ0   Brand: Whirlpool   Age: 5 - 10 years
Washer will not agitate or spin. Drains fine. Has a grinding noise from motor or transmission. I think this is the transmission, but at $160.00 plus, I would like to make sure before I order the part. Any help or suggestions would be appreciated. Thanks in adavance.
Related Models
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
  #2 (permalink)
Old 02-15-2009, 08:52 AM
TechnicianBrian's Avatar
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
You probably have a motor coupler (AP3963893) that has failed. If you look under the washer, see if you find anything that looks like ground rubber on the floor near the back of the motor. If you do, that is what is left of the coupler. The coupler connects the motor to the gear case and is the weak link in the drive to protect the more expensive components. A DIY'er repair if there ever was one, and much less than a gearbox.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 02-15-2009, 08:58 AM
Junior Member
Default
Thanks. Forgot to mention that the agitator will not turn by hand. Is it still the motor coupler? (I am hoping that it is.)
  #4 (permalink)
Old 02-15-2009, 09:24 AM
Senior Expert
APP Volunteer
Default
Look under the unit for rubber shavings and that will be a pretty sure sign. Use a flash light to look between the motor and gear case and you will be looking at it. The coupler may still be intact, but they will turn out inside. Once you have it off, the failure becomes very clear.
__________________
TechnicianBrian
TechnicianBrian.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Grinding noise during agitation Shadow99 Washer Repair 3 10-07-2013 02:04 PM
Knocking noise during agitation cycle Mark Rye Washer Repair 1 10-09-2009 01:49 PM
slight grinding, no agitation or spin oilspot Washer Repair 9 12-12-2008 09:39 AM
grinding noise during agitation kdeldridge Washer Repair 7 04-04-2008 06:24 PM
Washer noise during agitation insp-jim Washer Repair 5 01-08-2008 09:04 PM
