I have a GE the will fill up with water....then just sits there...will not agitate...then it will drain...........but then sits there and dont spin after it's drained. I have already tried the reset motor attempt and it's still not working. How do i get the front panel off to ck out the inside?
If you will post a model number so we can see what you have someone may be able to help you. If your machine is really less than one year old it should be under factory warranty.
