Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   water valve (http://forum.appliancepartspros.com/washer-repair/23357-water-valve.html)
Beverly Schoenbeck 02-11-2009 10:13 AM
water valve
How do I change the water valve? Do I have to remove the back cover from the washer?
denman 02-12-2009 04:57 AM
Without a model number it is a guess!!!
YES
Why do you want to replace it?
If it is shot the unit is still under warranty, place a service call.
Could be something else (more expensive) causing your problem.
Beverly Schoenbeck 02-12-2009 11:07 AM
Maytag Washer MAV7600AWW
How do I change a water valve on this washer. Do I have to remove the entire back cover of the washer? I have done this on a previous washer but it was easy and this one doesn't seem that I could get to it without remnoving the back cover. Thanks for your help.
