Discuss
getting pennies out of washing machine
 in
Washer Repair
Symptom-- Machine fails to drain every couple weeks. get code f04 and code sud. I open the drain pump and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » getting pennies out of washing machine
  #1 (permalink)
Old 02-11-2009, 06:10 AM
Junior Member
Nino Hero is on a distinguished road
Default getting pennies out of washing machine
Model Number: 110 44832 200   Brand: Kenmore   Age: 1 - 5 years
Symptom-- Machine fails to drain every couple weeks. get code f04 and code sud. I open the drain pump and find pennies, dimes (bt the looks of the coins, they have been in there a long time), chunks of plastic and remove them. Try a spin cycle and the machine does not drain. I watch the pump and see and hear the impeller blade spinning. I check the exhaust hose and it seems to be clear. By the way, there are no suds in the machine when I get the code.
1. Is it possible that the drain pump and motor is bad even though I can hear it and see it spin?
2. How can I get into the place where additional coins might be hiding? (Hope I find enuff to fix the machine!)
3. What makes that ball (in the drain hose) float and keeps the water from coming out of the machine.
Any advice direction would be appreciated!
nh
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
  #2 (permalink)
Old 02-12-2009, 03:48 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If there is water to the pump and the output clear of stuff, I would replace the pump AP3953640
This pump is an improved version of your old pump.
__________________
  #3 (permalink)
Old 02-21-2009, 08:24 AM
Junior Member
Default
Replaced pump. Machine has been working fine. No error codes. Drains. So, even though I saw the pump spinnining, it had to be replaced. lesson 2, when you tilt the machine 45 degrees, the weight of the tub moves the tub away from the pump and it is difficult to connect the drain pipe, so I had to use a clamp to bring the tub closer to the pump. I still can't figure out how to check for more debris in the machine. The pump was almost 1/2 price from the quote from the repair guy. I paid for the shipping 1 up from the cheapest ($6?) and I receieved my parts in 20 hours!!! Amazing. Replacintg the pump is an easy repair.
  #4 (permalink)
Old 02-21-2009, 10:34 AM
Senior Expert
APP Volunteer
Default
Glad you got it fixed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine Stops When Washing farmallnancy Washer Repair 1 12-01-2009 05:12 PM
Washing Machine candyanne Washer Repair 1 10-07-2009 06:24 AM
washing machine jrenn Washer Repair 0 11-09-2008 06:44 AM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
