Discuss
Washer fill stops after a few seconds
 in
Washer Repair
I am running into trouble with a Kenmore clothes washer, model No 11026732500. THE SYMPTOMS: the fill segment of all
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer fill stops after a few seconds
  #1 (permalink)
Old 02-10-2009, 03:13 PM
Junior Member
BaldHeadedGuy is on a distinguished road
Default Washer fill stops after a few seconds
Model Number: 11016732500   Brand: Kenmore   Age: 1 - 5 years
THE SYMPTOMS: the fill segment of all wash cycles opens the water valves and runs fine for anywhere from 10 seconds to perhaps 30 seconds and then it suddenly shuts off having not properly filled the tub. When it shuts off, there is no power to the timer unit – i.e. the timer motor is not operating as observed through the hole in the back of the timer case. Pushing the Timer Switch in and pulling it out again does restart the fill, but the same thing happens: fills for several seconds and then shuts off. I did observe one instance where the fill sequence did in fact operate until the water level switch shut it off and transferred power to the timer correctly completing the cycle, but once in 50 tries doesn't wash clothes.
There is no water in the plastic tube to the pressure switch, though blowing through the tube to the tub produces bubbles in the tub water. Blowing lightly into the pressure switch connector produces a click and starts the agitator motor; releasing the pressure starts the flow of water, again only for the few short seconds and then it stops. On the chance that there may have been a diaphragm weakness or a slow pressure release, the pressure switch was replaced – to no avail. As well the water-mixing valve was replaced on the possibility of intermittent electrical problem therein– A relatively easy and inexpensive fix, but again to no avail.
QUESTION 1: A basic electrical schematic with the machine shows a Timer Switch #2 [FOLLOW BLACK LEAD DOWN LEFT SIDE OF SCHEMATIC] that is identified on the switch open/closed contact chart as a ‘bypass’ switch that might (??) provide current to the timer. Is this the case? Or is it a switch that is energized by the timer to power the water level switch further on in the circuit?
Just beyond Timer Switch 2 in the circuit and seemingly in parallel with one another is a pair of Timer Switches numbered 31 (extra rinse) and 10 (fill).
QUESTION 2: Timer Switch #31 seems to feed a separate component that is not always used on all models. This model does have a control board switch identified as Rinse 1 and 2. Is this Rinse 1 and 2 the “extra rinse” of which they speak?
Timer Switch #10 (fill) appears to supply the center (violent) lead of the water level switch that either opens the water mixing valves or powers the motor.
QUESTION 3 and perhaps the most important: Since I have no means of telling whether these switches (2 and 10) operate incorrectly at the time of the problem, from your experience, is it in the realm of possibility that the contact(s) of the Timer Switch 10 are bad (loose, burned, pitted, broken o/r breaking) so that they cannot /do not maintain contact to supply voltage to the water level switch and on to the water mixing valve? From your experience is it the case that a bad or failing timer switch set can cause the symptoms I described?
Obviously I would prefer not having to replace the timer, especially if it is only to find out that it is not a bad part. Therefore, any help or leads that you can give me would be most deeply appreciated.
Thank you for your time and help.
BaldHeadedGuy
Ads By Google
Related Models
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
  #2 (permalink)
Old 02-10-2009, 04:16 PM
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
let,s say it,s #3..by removing the time off the washer, it,s easy to take a part.Remove the plastic slide and check for burnt contact[s].If so take a emery board[sand paper] and clean that contact[S] then install and try...gluk
__________________
  #3 (permalink)
Old 02-10-2009, 04:47 PM
Junior Member
Default Abbie re: Kenmore timer
Well, it sounds as though it is relatively easy to examine and tinker with the timer. My concern was that the easily opened snap-latch box would likely contain 3 million small pieces under spring tension so they'd spread themselves far and wide with 3 or 4 of the more important parts hiding under the 3 year pile of 'gotta keeps' in the corner. Your answer suggests it's not all that hard... crash helmet on, goggles down, charge!!!
Thanks for your help. We'll see how it goes.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cycle stops after 30 seconds Pattyr Washer Repair 2 12-16-2009 07:38 AM
Microwave stops after 59 seconds Nessguy Microwave Repair 2 12-02-2009 01:46 PM
GE Profile Washer only spins for 2 seconds, then stops, then smokes kurse Washer Repair 4 04-01-2009 05:53 PM
GE Washer Will Only Fill with Water..then stops! countryfolk Washer Repair 1 03-20-2009 04:02 AM
Maytag washer stops during water fill marcusr Washer Repair 3 04-07-2008 05:33 PM
